2007 suburban vibration
Sunny
pinion bearing and u-joints will cause a vibration also
U-joints for rear shaft have been changed recently , pinion bearing will make noise as per mechanic i really dont know whr shld i head ??
Sent from my SM-G955F using Tapatalk
Sunny
Have you checked the Motor mounts?
My vibration was with hard acceleration and horrible vibration around 65-80.
Did they say anything about your drive shaft when they balanced it?
Moto mounts checked looks good , very mild virbration feeling on steering wheel as well as driver seat , only on crusing light speed if i press hard gas pedal i dont feel anything .
Do u guys think this would be a clogged injector ??
No, a clogged injector would throw a code if it were that bad. Get yourself a Tech2 and this way you can monitor the engine in more detail.
Sunny
Ok thanks will do if anybody experience same plz share , iam thinking to give a shot with dealer .
traveus
traveus
What state do you live in sunny?
LRob
I know you have had your tires rotated/balanced a few times but it could be a tire thats slightly out of round or a rim thats slightly bent. I had a slight vibration at 65-70 with two different sets of wheels and i figured it would be something in the drive line like drive shaft or anything. Well i ended up buying some take off 22s from a denali and all went away. Even if a wheels balances out on the balancer, it may not detect an out of round condition.
Sunny
ok so I had 17s original then I changed the rims to 20s ltz rims , I even tried my orginal rims in tires as I kept them in my garage but same issue .
LRob
How long have they been sitting in the garage and whats the present condition of the tires?
Sunny
6 to 8 mnths but if we change the the complete set there shld a change if the previous running has problem .
Original tires do have good threads they r michelin .
ADO450r
