2007 Tahoe 5.3l AFM DOD delete thread
Geotrash
Dave
Richmond, VA
No...
The M355 is a higher volume pump for engines with AFM/VVT
The M295 is standard volume pump for engines without VVT or AFM
So you would see lower oil pressure with an M295 vs M355
There are *two* Melling oil pumps with the 355 designation. One is the 10355 (standard volume) and the other is the 10355HV (high volume). We need to know which one he installed. His engine needs a high volume pump.
wsteele
I was under the impression the high volume pump was for the AL block engines and the standard the iron block?
Not questioning your statement that he needs the high volume pump (empirical results sure would support that), just trying to get the data straight in my head. I was also under the impression a high volume pump on an iron block wouldn’t hurt anything.
wsteele
I just got off the Melling site and I think the various 355 oil pumps are for the 6.2L.
Essentially for the 5.3L 2007 model year your choice on their site is M295 or M295HV, with the HV being a higher volume pump. The high volume pump is their "high performance" line.
I can't understand the difference in the 295 and 355 figment wise as I thought all the accessories pretty much bolted right up, engine to engine.
Edit: I wonder if the issue is a 295 pickup line and a 355 O-Ring? Just guessing here.
Taheezy_88
Taheezy_88
That's the information I was reading last night. I am going to replace the m355 with the m295hv and seat a new Oring and go from there.
I have low oil pressure only when engine is cold and after I get to 210 degrees my oil pressure stays above 40psi even at idle.
Tahoe runs great otherwise.
Taheezy_88
Taheezy_88
My invoice
wsteele
That is strange that it is low when cold and higher when hot. I don't think I have ever seen that.
FWIW, minimum acceptable oil pressures, according to my GM shop manual, are 6 psi at 1000 rpm, 18 psi at 2000 rpm and 24 psi at 4000 rpm. Personally, I wouldn't run it that low and would be looking to fix it, but that is what the book says.
wsteele
I also saw an offering that is both high pressure and high volume (I think it is 10296), I couldn't find that this last search though, might be old nomenclature.
Taheezy_88
Taheezy_88
When starting it, the pressure will shoot up to 40-60 psi and slowly drop down to zero then I get the low oil pressure warning light. After driving around for a couple minutes the pressure stabilizes above 40psi.
wsteele
Very strange, I wish I could be more help. It would be interesting to know if the 6.2L pickup tube is a different diameter than the 5.3L.
Edit, on Rock Auto's site, they list the same Melling pickup tube for both the 5.3L and 6.2L, so it doesn't appear the O-Ring is the issue.
Taheezy_88
Taheezy_88
The oring I inserted was the green one and it fitted snug enough where it didn't even feel like it had to be bolted on the pump. So I'm hesitant to blame the oring.
valentinitoronto
