2008 Denali XL 6.2L Low Oil Pressure - Fixed
Tonyv__
Bucks county PA
Idk if we talked about this--I had to change the oil pump in my 05. The O ring was still soft and pliable--but this motor was severely neglected.View attachment 271114 View attachment 271115 View attachment 271116 View attachment 271117 View attachment 271118
I put a high volume, now warm idle pressure is around 50 psi. From the low oil pressure, that eventually went to 0 it developed a tap. The tap slowly went away. As of now motor has 150,000 on it.
We did. It’s in my inbox. About a year ago lmao. That’s probably why I didn’t do the o ring because I didn’t wanna guess and waste my time. Also my van doesn’t fit in my garage with the ladder racks. So more of a hassle to get to work on it.
It def is a pita job.
Tonyv__
Bucks county PA
Any special tools? You mentioned the timing chain cover comes off for the pump.. I see the water pump comes off. That’s simple. Does the harmonic balancer come off too? And do I need a special puller?
1BADI5
DMV
Yes the balancer will have to be removed.
Tonyv__
Bucks county PA
Might sound like a stupid question. But does the balancer need anything to be re installed. Like does it need to be balanced lol. And I might as well maybe do the chain while I’m in there
1BADI5
DMV
Nope its a remove and replace item.
But you will need a puller / install tool set and a way to hold the flywheel.
I can post up the tools later too. Always install with a new crank bolt since they're a torque to yield bolt (aka one time use).
Thx for chiming in. I didn't personally do the job, friend of mine did. He did use the same crank bolt tho--so far no ill effects. Def change it tho.
Polomatt
