2009 Tahoe..P0641 code appearing ONLY when it rains - SOLVED
Jeffgt500
Alright it’s been a min since I’ve fixed it but I wanna conclude this invade anyone ever had a similar problem. Before I go further thank y’all for the help. So I ended replacing every sensor in the 5volt reference circuit: oil pressure, a/c line sensor, map sensor, camshaft position sensor, and fuel tank pressure sensor. Nothing worked. I replaced my entire engine harness. Didn’t work. Swapped computers (ended up being a bad replacement) but found out my original computer was fine. I had brought it to a electrical shop before I replaced the harness as the problem was occurring and was told they couldn’t find it and they even sprayed the truck to try to get it to happen again and didn’t work. Was told by them that this problem is only possible in the engine harness and couldn’t be in the body control module or body harness. Wrong. I decided to spray every electrical connection underneath the truck and isolated it to a section of body harness under the drivers side inbetween the front door and the rear fender. Pulled my entire body harness out of the truck to where it runs down from the front wheel well to where I found a single nick in a blue wire that had corroded. This spot had a rubber section that went around the harness to protect it from the body mount for the cab to the frame. The rubber was on backwards where the opening was touching the mount allowing the wires to rub the cab mount and eventually led to the blue wire stripping and grounding out. I cut, spliced, soldered, and heat shrinked it back up and I’m good to go now. Zero issues.
I just wanted to let you know just how much I appreciate your follow up. I have a 2011 doing EXACTLY that same thing. I still have to get under it when I get home (truck driver) but I think this is going to save me a lot of time and money!
Kerrick k
