2011 Tahoe LTZ Electronics shut down, loss of power, and Service Traction Control, Stabilitrac off, reduced engine power msg coming on
B
Brawny
Ok. That's a clue. The alternator is running at full output trying to keep that battery going and you guys from getting stuck.
Like we said before, corroded or loose wires can cause this or it might just be time for a new battery.
If you have an advanced scan tool, you can pull up the state of charge. If it is below 65%, it's out of spec and needs replacement.
If you do not. Let the truck sit overnight and put a voltmeter on it in the morning. Compare the voltage with the outside temperature to get an idea of the state of charge according to this chart:
Sorry, life got in the way and I never did respond. I did replace the brake light switch and everything went well, until today. When I get a chance I'll look into all the stuff you mentioned. Thanks! Right now I'm disconnecting the negative to see if I can get it to reset. At least so I can get it back to the house.
Emmell
