2011 Tahoe squeaking
PeteCT
Gotten oil leak somewhere around the filter and plug
Not sure where yet any heads up on a possibility’s
More than likely your oil pan gasket is leaking. I had same problem, when I pulled down the pan, the gasket was cracked. I didn't change the gasket, just sealed it and that's it. Leak is gone.
I don't know if you solved your problem with squicking, I had same issue. Here's the thread https://www.tahoeyukonforum.com/thr...lts-turned-on-sound-still-there.114907/page-3, in the end is the solution. Good luck!
Monz11
Da Burg, Fl
Has anyone upgraded their oil pan? If so, what brands did you consider, i.e. Moroso, Holley. Summit, etc. and what did you end up getting and why?
91RS
GA
What would be the reason? I don't see anything wrong with the factory oil pan. If you want to upgrade something, do the oil pump and get a Melling.
jrmhokie
