2012 Airbag Reset
aniwack
I got a 2012 PPV with a bad passenger airbag seat sensor. I changed out the seat (the cloth was torn to shreads) and now to clear the error I need the system recalibrated. The local can fix anything guru doesn’t have the computer to reset the system. Am I stuck with having to wait 8 months on a dealer tech to push a button and charging me out the ass?
Sparksalot
Bastrop County, Texas
I've understood that entire system calibrates itself after component changes. Did you disconnect the battery while doing the swap out?
It won't clear until the fix is made. SRS codes are "permanent" codes, meaning they might be able to be reset with a scanner but if there's a problem with the system, the code will set immediately upon power-up.
It could just be the sensor calibration for the correct passenger weight. I'm not sure about these seats but other manufacturers have a procedure where a specific weighted pad is used for the calibration, so the sensor can tell whether or not the passenger -- or the box that's sitting on the seat LOL -- weighs enough to activate the airbag for that seat.
F9thSkynet
