2012 Escalade Premium Dual Exhaust Rear Fascia/Bumper COMPLETE
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
I guess that one works with the tahoe ... but too small for our 6.2s no? :think:
your better off hp wise keeping the stock 3.5 inch exhaust set up and replacing main muffler with the 3.5 in/out magnaflow like I did on that set up.
soulsea
Bar
Plus I've looked under my truck ... I can't see how that pipe can squeeze tween the axle and spare. Let's put it this way way ... better hope that spare is made of the same stuff steelworkers use to protect themselves from the smelter, or else is kaboom!
soulsea
Bar
require Cutting and Welding :superhack::weld:
Yeah well, cut and weld yourself a composite high tech heat shield if you plan on keeping that spare ... I'm not kidding. With all that stuff so close to each other where it's not meant to be, at the very least you're going to melt the spare (which renders the whole exercise of trying to keep it moot), and at worse set your truck ass on fire ... and the gas tank ain't too far.
soulsea
Bar
there is no room for the spare tire
Oh okay that's what it looked like to me as well.
Man I wish you could have figured it out whilst retaining the spare ... you were so close with the hitch access relocation. :(
---------- Post added at 02:20 AM ---------- Previous post was at 02:16 AM ----------
at least his bumper/exhaust will look bad ass :p
No doubt, it already looks amazing.
That was never in question as most of us agree with the killer look of it. But GM deleted the spare on the esky premium to option out the dual exhaust bumper.
So we've been trying to figure out a way to retain it ... the actual look of the dual setup wasn't the issue. :waytogo:
I ve been working the noggin overtime trying to find a solution ... a while back I stated that there doesn't seem to be a way to do this whilst retaining the spare. I really hate being right about this. Ugh!
soulsea
Bar
Then what was the point of that mod to the bumper to get access to the hoist?? :think:
I guess it's the price of guinea pigging a new setup ... although anyone taking the time to look under their truck with a tape measure would have noted that squeezing an exhaust tween the axle and the existing spare was always going to be difficult if not impossible. :shrug:
@esca: Well, getting a different size tire is also going to be difficult ... the issue you have isn't related to the width of the tire but with the overall diameter/circumference.
The wheel/tire you have on there now retains approximately the same diameter as your stock ones ... if you put a smaller diameter tire it's going to lean the truck should you ever need to use it. I just went and looked again, not sure if the Tahoe is the same as the Denali, but I also have a sway bar even closer to the spare than the axle.
So I think it's time for this: http://www.ebay.com/itm/10-11-Chevr...s&hash=item4161b3fc57&vxp=mtr#ht_12087wt_1103
THE YETI
THE YETI
Director of Operations
South FL
spares arent designed in theory to get you to drive all over town until you get a tire next week. They are designed for temporary use to get you to the nearest facility. Times have changed a bit where manufacturers are putting full size spares on because they know barely anyone is doing this anymore...however, keep in mind that some cars use "donuts" still, which arent the same size as a normal full size tire. Putting on a smaller diameter tire to get to the nearest shop isn't going to hinder anything or cause the vehicle to lean so dramatically that it cannot be driven.
just my thoughts...
Jordan0277
