2012 Yukon Denali won't try to turn over.
Kurt Johnson
Our 2012 Yukon Denali was running perfect. Took it to the detailer and they said it wouldn't start. Battery is charged. Also the rear hatch won't open now. It's almost like the vehicle won't let it start because the computer thinks the car is in gear?
Anyone familiar with this issue. Everything lights on the dash as normal.
Thank you!
Multnomah Falls
Theft deterrent causing problems. Might try taking the battery cables off and wait 1 minute and then touch the cable ends together and reinstall and see what happens. This is just a WAG.
Thank you!
What did you take it to the dealer for? They ought to put a Tech-2l on it and find out what's wrong.
Kurt Johnson
Kurt Johnson
Sorry. The detailer (car wash detailer) discovered the issue while they had the Yukon. We towed it to a Christian Brothers franchise and they couldn't figure it out because the diagnostic tools they use wouldn't show anything at all. We then towed it to a dealer. They are trying now.
Multnomah Falls
So the rig started when they pulled in to do the detailing and then would not restart to get it outside. This statement is a bit off then," Took it to the detailer and they said it wouldn't start." Made it sound like they never got to do anything to it because it would not start to pull inside.
Kurt Johnson
Kurt Johnson
Does it help to diagnose the issue knowing whether they were able to wash and detail the car?
They washed the car pulled it out of the car wash to vacuum and clean the interior. Presume they turned it off at this point. When they finished detailing the interior it wouldn't start again.
Five Twenty
