2013 Suburban, rattle or tapping noise from the right rear wheel well area.
George B
George B
¯\_(ツ)_/¯
Oconomowoc, Wisconsin 53066
I decided to go ahead and order enough of the little mount insulator things do do the whole side of the truck. Since I will have all the mount bolts out and that side lifted. Who wants to bet I get a noise on the other side after this?
St. Louis
Probably will, but at least you will know what is causing it!
George B
George B
¯\_(ツ)_/¯
While I am waiting for parts I am trying to figure out what lifting point to use for lifting the body. I planned to use a 4x4 to spread the weight. I was thinking of lifting between the #3 and #4 mounts as far out near the rocker as possible.
the upfitter guide might have some kind of info on that.
jz57
Put a few peices of big metal washers between the worn bushing, you are good to go.
ziggy1949
