2015 Suburban LTZ - Suspension Problems
JWAustinVTX
Howdy,
My 2015 LTZ suspension feels terrible. I suspect the it's the front struts. Rides very stiff and kinda bounces with every little bump, like it's completely compressed. Taking it into a local shop Monday for a diagnosis.
Curious if this has been discussed before or if anyone has experienced this. Over the phone the dealer said struts would not be covered under warranty or extended warranty.
TIA
GMT800 SUV/Trucks
Sounds like it could be struts and they are a wear item so warranty coverage can be spotty. You did not say how many miles are on the Sub. Never take the word of the dealer as to what is covered in an extended warranty. Get you contract out and read it.
AZCreeker
replace worn out Shocks with OEM ones that are a match to your vin/build code in the glove box.
While I change my oem to Bilstein 5100's, and people here will tell you that stock are junk and better change to aftermarket, safest and easiest thing to do to get back to as good as new ride is just stock.
all lift/aftermarket suspension, while they give you more control and more dampening won't result in a more confortable ride, what you feel the truck transmitting trought your seat.
Just my 2 cents
Tahoe14
Central Fl
Yes it has been discussed before. Just do a Google search. There may have even been a TSB if I remember correctly for the magnetic ride control. There is a new part number that is suppose to be an updated part. Do not pay Dealer prices. Google search the part number and several sites should pop up, Ebay, Amazon, Rockauto ect, ect. Good luck.
Tahoe14
Central Fl
I forgot to mention that on the Corvette forum they talked about the magnetic ride control and were able to get the struts replaced with the GMPP extended warranty plan.
JasonK
Just my 2 cents
How did the swap to the bilstein's go? I am planning to switch over, but heard there are a few parts from the LTZ that do not work with the Bilstein's all that well - mainly the upper and lower coil mounts. How did you overcome that?
AZCreeker
I couldnt tell you, I had my chevy delaership do it.
My suburban had regular coil suspension, so it was an easy swap
Jay_Rye283
