2016 Yukon Denali 4x4 4” Fabtech
Powder Toast Man
@Nokturnal I am planning on running 20x10 -24 wheels on my 16 Denali xl. I put the suspension max 2.5" up front. The wheels have 305/55 worn out tires on them now but when I test fit them the hit the power steps pretty bad. I'm thinking about different tire sizes and was wondering if you had any input on clearances. Using tire size calculators it looks like a 275/55 should clear.
Jerry Rabenaldt
I have run 305/50's in place of the 275/55's for a wider stance if that's the part of the look you're going for.
Nokturnal
Nokturnal
I had 33 x 12.5 x 20. My offset when I had the 2.5 suspensionmaxx was 0 on 20x9. Stepping up to -24 and 10 inch wheel you’re moving it out more than an 1” and I bet you’d need to go at least 3-3.5” to not have rubbing issues. I went with the fabtech 4” budget kit and then switched wheels to the 20x10 -24 and there was no rub on my brand new 33 x 12.5 x 20 MT’s
Powder Toast Man
I went ahead and got fallen at3w 275/55 tires. I put the wheels on today and they fit with no rubbing at all. Suspensionmaxx 2.0" total up closefront.Very stock in rear. Stock mag ride with air assist in rear. though but clears. I'll take better pictures tomorrow and post in a new thread to help others. I am getting an alignment tomorrow to add some positive caster to give a little more cushion. Thanks for the reply.
olyelr
Elk Rapids, MI
View attachment 270581 View attachment 270582 View attachment 270583
nice. Have the same tires on my truck and my wifes denali. Really like em.
isnt that the oem/stock size tires?
quikdime
