it only works on certain vehicles, which is why it say''s (if equipped)Hmmm, interesting. Dealer told me I couldn’t but I’ll have to try it. ACC is horrific.
it's came up in discussion before that some years had the option and some did not, may have something to do with the trim level or optional packages ordered, not really sure.If equipped with an additional option to turn it off lol? Weird option!
I get the vibration in the seat. A dealers favorite thing to say is "everything is working as it should".My vehicle is 13 months old and I just turned over 10k miles. About a week ago I developed a change in my Lane Departure Warning and my Front Parking Assist. I use to get a vibrating seat as soon as the icon for either of these changed in the drivers display. Now the icons change but no vibration or beep (selectble in vehicle settings in the Infotainment Center.) I do get a vibration when the rear sensors detect something.
I had the vehicle at the dealer today and they contacted GMC. The answer they gave me is that the vehicle is behaving as designed!! I can't believe this, since for 13 months it would vibrate immediately when the lane departure icon changed from green to amber.
Having and icon change color is not much of a warning! A vibration or beep is needed and it use to be there.
How is the system working in your vehicle??
Can anyone confirm if my system is operating correctly? I have a 2019 GMC Yukon SLT with lane keep assist as part of the build sheet data. In my opinion, the lane keep assist works very well. The lane keep assist icon will change from GREEN to AMBER and then the electric steering will attempt to correct me. It is very accurate and does a good job.
However, if I don't signal and the vehicle does move out of the lane, nothing happens. The icon doesn't flash at all and just turns off completely as if it is no longer detecting any lane markings. In the two months I have owned the vehicle I have never experienced a lane departure warning of any kind. I have my alerts set to AUDIBLE so I should be hearing a beep rather than a seat vibration.
However I am getting proper beeping for the front and rear parking sensors. But, I don't get any beeping for the blind spot alert. The symbol in the mirror will flash but I do not get any audible alert for that either.
I'm trying to determine if everything is functioning as intended or not. From my searching there is no sound answer as it seems vehicle owners have a lot of varying things to say about lane keep assist/lane departure warning.
I’m trying to understand your questions. In paragraph 1 you state lane keep assist works, and the way you describe it is the way mine works.
Paragraph 2 you state if you do NOT signal? Isn’t that the same use case as paragraph 1? Because if you do signal then lane keep assist is disabled.
Paragraph 3: that functions as designed. I don’t get any audible warning from blind spot warnings. It’s all visual.
