2021 Tahoe PPV massive oem brakes, 16"
TTahoes
This thread is great for info, thanks all! In the last month I have swapped my 2011 Escalade, and 2024 Yukon.
Below is the list of what I used for my 2024 Yukon swap. The PPV j55 Tahoe has different brake hoses listed, I have confirmed those fit. Also as stated before, the rear wear sensor works for the front calipers.
I ended up customizing a 18mm socket so I could remove the hub bolts without removing any ball joints, just need to tap the axle back a little.
I will keep an eye on brake dust, I believe it was said the Brembo pads make a lot of dust? My 2011 Escalade has power stop pads, so I should be able to compare.
PPV J55 2021+ brakes:
16" Rotor weight 87839222 40.8 pounds
6 piston caliper 84793057 weight w/pads 19 pounds
2021+ SUV standard brakes:
14" stock rotor 29.2 pounds
4 piston caliper w/pads and brake hose 19.8 pounds
GMt900:
13" rotor 25.4 pounds
2 piston caliper and bracket 18.8 pounds
2021 PPV j55 Tahoe, VIN to use 1GNSCLED6MR283980
GM GENUINE
84793057​
Caliper (Drivers Side) Brembo​
GM GENUINE
84793058​
Caliper (Passenger Side) Brembo​
GM GENUINE
11569590​
Banjo Bolt x2 ( M10x1)​
GM GENUINE
21012386​
Banjo Bolt Washer x4​
GM GENUINE
11546469​
Caliper Bolt x4​
GM GENUINE
84495310 (84763236)​
Brake Backing Plate (Passenger side)​
GM GENUINE
84495309 (84763235)​
Brake Backing Plate (Drivers side)​
GM GENUINE
84688287​
rear pad wear sensor (longer lead and reach on sensor end)​
GM GENUINE
84987498​
Front Brake Pads (Heavy Duty, hardware not included) Brembo​
GM GENUINE
87839222​
Front Brake Rotor (Heavy Duty) x2​
GM GENUINE
86555794​
Caliper hardware kit (pins and pad spring plate)​
GM GENUINE
84956404​
Front Left J55 brake hose (w/banjo bolt and washers)​
GM GENUINE
84956405​
Front Right J55 brake hose (w/banjo bolt and washers)​
alternativeNapa
FLT FT9637​
Fleet brake pad (includes caliper hardware)​
alternativePOWER STOP
AR82209XPR​
Rotors (both sides)​
Z37-2407​
Brake Pad (both sides, pins included)​
Thanks for putting this together. After seeing these on a PPV and seeing that I could order the parts on Rock Auto vs the "performance kit" I started putting part numbers together. Since you did it first, I will be using this list when my wife's 2023 Yukon's brakes wear out which shouldn't be too much longer. The stock brake setup is terrible. Worse than my 2018 for sure.
soundguyone
Definitely the best upgrade I've made yet. For the sub $2,000 cost; it's certainly worth it. I opted to paint them myself, had decals cut and then properly cleared over top.
Jordan0277
