2022 Tahoe: Rear-end collision now issues with liftgate window. Anyone got a '22 to help me compare?
BlaineBug
Clown World
My 19 has to be slammed pretty firmly too - always makes me nervous to do that to a frameless window. I don't use the tailgate window much at all as a result.
I'll elaborate, I wish the window didn't open at all. Having that one central latch seems like a serious security weak point too.
WalleyeMikeIII
Sunny and Snowy Minnesota
I have always loved that the rear window opens. You can load significantly more cargo that way...and often if I have only one item to put in the back, I'll use the window vs. the liftgate. That said, I am 6'4", and have long arms. Wouldn't work for a person shorter in stature. As for the security, whether it be a latch or just a pane of glass, the security risk is the same, you will have to shatter the glass before you get that latch open...crook just going to use a window breaker either way.
BlaineBug
Clown World
I wonder if my window shattering concerns are valid. I could see use on our recent road trip where I had a loaded largo basket in the rear that prevented tailgate from opening. But I refused to use the window so far away from home!
WalleyeMikeIII
It is pretty unlikely you would break it by using it as intended. You might break it if you closed it on to something, etc...but it is a pretty strong piece of tempered glass. I used the one on my 2013 several times a week for the entire 9 years I owned it. Just make sure when you close it, you are closing it "at the latch" by using that area as the push area. Never heard of anyone breaking this by using it as intended.
Josejr00
