Back window and side body be flexin'.
Thanks, considering selling it all. Thats how I do things...the thrill of the project often dies quickly once done . I didnt swap the battery, I added on a D4S LTO 6.0, which runs inline (fused) with the stock battery. Stock alternator.Nice setup. I have a 15” FI Audio in a 21 Tahoe. Did you add a High Output Alternator?
When swapping battery, did you keep power connected to the vehicle at all times or disconnected pos/neg and swapped battery/lithium like nothing and have no issues reconnecting a new power supply (battery)?
it may be worth noting it will sound a lot better with the sub facing the rearThanks, considering selling it all. Thats how I do things...the thrill of the project often dies quickly once done . I didnt swap the battery, I added on a D4S LTO 6.0, which runs inline (fused) with the stock battery. Stock alternator.
Might end up giving my wife the AT4 since she is in need of a new car and ive been looking at getting another M5 .
View attachment 424400Goal with the system is to be able to "quickly" remove the box if/when needed for vacations or hauling large items.
I see, nice. I considered lithium but not sure I could charge my agm with the ctek 7002 trickle charger w/a lithium wired with the stock agmThanks, considering selling it all. Thats how I do things...the thrill of the project often dies quickly once done . I didnt swap the battery, I added on a D4S LTO 6.0, which runs inline (fused) with the stock battery. Stock alternator.
Yeah, but the box it so damn big to where it just fits and still allows the seat to go up/down. Worried that if I turned around it (sub) would either hit the liftgate or slide back when spirited take off's from the line.it may be worth noting it will sound a lot better with the sub facing the rear
You disconnect the Lithium from the AGM setup when charging. I borrowed a friends lithium charger to top it off, added it to my setup, and that was it.I see, nice. I considered lithium but not sure I could charge my agm with the ctek 7002 trickle charger w/a lithium wired with the stock agm
