2022 Yukon Denali
mikew2069
How's the brake dust on those brembos? Curious if its the typical brembo dust or if they used a low dust pad.
kcb14214
kcb14214
100% agree that the price that GM/Dealer charges on those rims are overpriced. Def way better options with other 3rd party vendors.
Whenever my order gets picked up (supposedly January now) I have a couple 22s picked out and going to try to swap out the stock 22s for some 20s to use for the winter months of Michigan.
Yeah, I had my last two come through with the bottom of the barrel and then I put some nice chip foose style wheels on it.
kcb14214
kcb14214
No idea yet. Ceramic coating them and the whole truck the 6th.
kcb14214
kcb14214
How do you install a Roku in the back?
I installed a roku stick powered off the usb c in the rear center console with and hdmi cable into the same spot. Then linked it to the wifi, kids can watch disney, apple, netflix etc. there is a great writeup on here.
kcb14214
kcb14214
Installed the GMC mirror puddle lights last night, look great.
AWSMBLU
Be careful of the Brembro brake package. If you get a flat on the front your spare will not fit over it. You must change the rear tire 1st then swap it out with the front. Found out the hard way. The min size is 20 inch. I tried to put a 20inch spare underneath. Won't fit.
kcb14214
kcb14214
Yeah, was warned before I drove off the lot. Its in the manual as well.
AWSMBLU
Well when I purchased mine no one warned me of that issue. Just passing it on
kcb14214
kcb14214
Ok. I knew before I ordered it as well. I used to run 18” steelie’s for winter rims. Knew they wouldn’t fit over these. But the brakes are awesome.
97ext
