What engine do you have and what octane gasoline are you using? If not using the recommended fuel, that may lead to premature or retarded combustion (which in theory should be compensated by knock sensors).I have around 3,000 miles on my new Yukon. after owning it a while I have noticed a slight shudder or vibration while downshifting around 13mph. has anyone else experienced this?
5.3l and 87What engine do you have and what octane gasoline are you using? If not using the recommended fuel, that may lead to premature or retarded combustion (which in theory should be compensated by knock sensors).
Engine can be warm or cold. and when just braking normal. feels like you are going over rumble sticks. but its very slightDoes it happen on all downshifts or on gentle stops or aggresive stops? Happen when engine warmed up or cold?
Any update on this? I notice it on mine too.Engine can be warm or cold. and when just braking normal. feels like you are going over rumble sticks. but its very slight
Took it to local dealership and had service manager and tech drive it around. They believe its in the transmission. I had to call the dealership i bought it from so i could make sure i got a loaner. i drop it off monday!Any update on this? I notice it on mine too.
Did they determine the cause?Took it to local dealership and had service manager and tech drive it around. They believe its in the transmission. I had to call the dealership i bought it from so i could make sure i got a loaner. i drop it off monday!
