24 inch wheels causing steering wheel to shake
DwDrummer
AL
When you hit your brakes does it shake your truck really bad? If so the hub centric rings will help this.....benn there done that!
D
dlouis
DW it shakes a little..when I do...I will get those hubcentric rings, but from where? Is there a place online where I can get them?
DwDrummer
AL
Call the place where you got your wheels from and they be able to hook you up with a set!
mdtahoe
You need to find a shop with a top of the line balancer ( hunter GSP 9700) That is capable of Road Force Analysis. No wheel and no tire are perfectly round so even if they are balanced they may hop. That machine has the ability to measure that and show you where to match mount them for the most round assembly. Also wheels that big are tricky to balance and you can not use a cheap machine. I would highly suspect they are not balance properly.
D
dlouis
ok Ill check this out, anyone know how to get the steering stabilizer?
Modded
That Guy
You don't need a steering stabilizer unless you have alternated suspension.
After you get hubcentric rings and properly balance your wheel the car will ride perfect!!
gmw33
I just got my 26s on and they are fine up until about 70mph, and then i get a shake and vibration. nothing too severe, but somewhat annoying.. Sucks im driving 6 hours tomorrow in it, hopefully nothing gets thrown off.
Modded
That Guy
Get some hibcemtrics rings and you'll be fine, may even be able to do it before your trip!
gmw33
im pretty sure ive already got them, Orange rings between the hub and wheel
OklahomaSideShow
