3 15 kicker cvr's
blueflamed03
Oklahoma
not according to kicker.com
he has the cvr-alums
this is copied direct from kickers site....
I work for Kicker...
CVR in DVC has always come in dual 2, and dual 4. Except back when they were ONLY available in SVC, like 88-to early 90's.
I have done a TON of systems, and the loudest by far for me, was one Solo X 12" ported off a KX2500.1 ran at 1 ohm.In my old Tahoe was sick...
droppedHoe
Lawrenceville,Ga
o ok, thats cool and all i was just saying i got the info direct off kickers site so if you work for kicker you may wanna tell them to change that on the site b/c its misleading...
as for the solox 12. i had it in a gs400 lexus and it was cool but just wasnt loud as i thought it would be..i also ran a 2500.1 and the bench sheet it came with said 2937rms@1ohm... i sold the solo, got a 9512 and it sounded so much better, on a termlab it was 1.8db louder but felt and sounded much louder than that... dropped lower too... i was real impressed for a single 12
ive also had friends swap solox15s for dc lvl4als and it went from loud to wtf is back there lol...
sorry no more love for kicker from me.. only like some of their amps and even they're over priced honestly
blueflamed03
Oklahoma
dont know what your clickin, direct from site, Kicker CVR specs:
Choose Model:15"|12"|10"|8"
Model CVR15
Size (IN.,CM) 15, 38.0
Impedance (OHMS) 2 or 4 DVC
Max Rec Amplifier Power (WATTS PEAK/RMS)* 1000/500
Sensitivity (dB 1w/1m) 89.2
Frequency Response (Hz) 25-500
Mounting Depth (IN.,CM) 8 3/16, 20.7
Mounting Cutout (IN.,CM) 13 11/16, 34.7
Min Rec Sealed Box Volume (CU. FT., Liters) 1.8, 51
Max Rec Sealed Box Volume (CU. FT., Liters) 5.2, 147
Min Rec Vented Box Volume (CU. Ft., Liters)** 3, 85
Max Rec Vented Box Volume (CU. Ft., Liters)** 5, 142
A ported Solo X 12 and a DD would require totally different boxes and tuning for optimal.
And we dont, nor ever have made Solo X 15's, so your sure your not confused on woofers?
and sorry we are not your butter for your bread, but we do well for a 38 year old compnay, I'm pleased.
alxs210
alxs210
Reno, NV
So I took it to the Guy yesterday and i guess he did something wrong with the wiring or something, its all confusing to me. Now its hitting hard! 125+db. I'm satisfied now. Thanks gguys for the help and having put up with me. :)
MOBmentality
Has a $25,000 Punch
he wired it like I told you to... lol.. now you have twice the watts going to it..
Glad youre happy with it now..
now its time for a new video!!!
Huck
Whut Thee Huck?!
San Diego
Where's the hook up?
blueflamed03
Oklahoma
cool, glad it working like it should now. :)
Huck, I JUST now added a system in my own ride...LOL
droppedHoe
Lawrenceville,Ga
Model CVR15
AGGGGGHHHH LOL
cvr and cvr-aluminized.....
as you see alxs210 is running the cvr-aluminized subs...
as you see if you click on the CORRECT sub on the "kicker website" is list this:
Comp VR aluminized (available only at select retailers)
* 15- and 10-inch models available in 4-Ohm DVC
* 12-inch model available in 2- or 4-Ohm DVC
* Injection-molded polypropylene cone with tough aluminized coating
* Perimeter venting around rugged steel basket removes damaging heat
* Vented pole piece/back plate for additional protection against heat
* Constant-contact back bracing on cone further eliminates flex and distortion
* Progressive roll, polycotton spider for improved linearity at high volumes
* High-temp coil wire
* Durable Spiralead™ tinsel-lead technology
* Polyimide high-temp former
* Ribbed Santoprene® surround for strength at high excursion
as you see* 15- and 10-inch models available in 4-Ohm DVC
http://www.kicker.com/compvr_aluminized
Direct link from the company you work for ;)
Not trying to be an ******* but brah... its right there...... :hands:
as for the soloX.
the box(S) were built to kicker specs from a kicker dealer.
one was 6cubes tuned to 45hz as specs said.. sounded very sloppy to me. so they made a new one that was tuned to 38hz... and i wasnt satisfied with the output. then they said to try a smaller box but it would push the thermal limits quicker.. tried 4cubes tuned to 38hz... sounded tighter but damn right, wouldnt take the 2500.1 well.. it would bottom out easy even with a subsonic filter at 25hz...
so $700 later worth of boxes i took the soloX out...
bought the 9512D and it was put into 3.2 cubes after displacement tuned to 34hz... sounded awesome. got loud as hell, got lower and took the 2500.1 no problem...
simply put better overall sub hands down
as for my boy chris with the solox's.. he said he has solox 18s.. i thought they we're 15s b/c they didnt look THAT big when i saw them. but a co worker has l7 15s and i can see the size difference easily now. but chris said he's putting them in a crx he's building for burps. gonna run 12k on each one(probably wont last to many burps)
he took them outta his daily driver a little over 2 months ago and put 2 dc audio lvl4xl 15s in and its seriously louder with the same power. he's running a digital designs z2 and those subs dont break a sweat but the solox's surrounds ripped 2-3 times and kept getting them reconed. he told me they just arent designed well for daily so he's gonna see what the solox's will do for burps.
my first system at 17 was a full kicker system and i was very satisfied which is why i became a repeat customer but now that i ventured out i'll never go back...i do still have my kx2500.1 but it has a few blown mosfets... messing around one day and voltage dropped badly... the place i was gonna fixed at said $300 so right now its a paper weight b/c im getting my crescendo 5500 soon as they start shipping on the 20th, called in today with my american express card number :)
blueflamed03
Oklahoma
That is showing what is 'available' now to still purchase, old tech manuals for a 2007 woofer are still in the tech area.
http://www.kicker.com/sites/default/files/2007CompVR.pdf
Some older alum CVR's are still available, but not all impedances.
Thats why it states clearly (available only at select retailers)
Dont know what your prob was, I used to run our Competition Team and they ( most Street A, B and C and up) ran Solo X and won many World Titles.
Dont know, maybe they did something magical.
6 cubes is HUGE for one 12's.........no wonder it sounded bad.
matter of fact, Rusty, owner of DC, his wife Ana used to be on my team. She ran Street A and dominated. Used Solo x's if I remember right. Rusty, Ana and I go way back.
If your box was tuned at 38hz, SSF set at 25hz, and they bottomed out, you simply were unloading them in a ported box. Playing well below tuning frequency. Thats not a subs fault. You didnt bottom out a Solo X, look at the T-cut top plate, with that power, next to impossible. Unloaded it, yes. Bottom it out, I doubt.
DD makes great subs, about 60 miles from me. A better overall sub(?), well, to you. Maybe it doesnt work for others that have tried and got the X louder, dunno.
The 18's might, depends on install and user, my Comp team won USACi with three L5 10's, with out 3000 to each.
story --> http://www.kicker.com/Sound_Off_MythBusters_Take_All_Players_and_Win
But I wont sit and debate which is better, or worse.
Get what works for you.
The OP was taken care of, debate over.
This is the exact reason I didint want to state I work here, it always turns into a debate with someone.......
hawk Eric
