IM not a fan of Crescendo amps since they are really just rebuilt power accoustic amps.. if you take two apart next to each other its as painfully obvious as a needle in your eye.
but thats beside the point
We do need to make sure youre getting the most power from your amp possible.. and to do that we need to start by going backwards.. dropped is assuming youre getting 2.5 which is just kinda a common number people apply to a 3 1ohm setup ran in series..
3 divided by 1 minus resistance is 2.5ish which in the case of your amp puts you power somewhere around.. poop.
So this is gonna take popping the speakers out but we can get you closer to your 500w rms by getting you closer to 1ohm by INCREASING ohm load on the subs then dividing as a whole..
Just so you know whats going on right now you have 2-2ohm voice coils per sub.. ran in Parallel to give each sub a 1ohm resistance, divide 2 by 2 = 1... then those three are ADDED together to run to the amp in Series.. which ADDS 1(ohm load) x 3 (speakers) giving you 3ohms .. because of the magic of efficiency it end up being 2.5(ish) and your 1ohm stable amp is doing shit for power..
What you NEED to do is make the math work FOR YOU.. instead of trying to make each speaker 1 ohm.. run the speaker itself in SERIES making a dual 2ohm Voice Coil a 4 ohhm speaker.. then run each speaker into the amp as a Parallel loop..
so you get 4(ohm) DIVIDED by 3 (speakers) which is 1.333333 which in a perfect world will look more like 1.15 on the amp.
Your amp will be putting out twice the power.. and alot closer to the rms of the speaker and the max efficiency of the amp...
It looks like this...
This is your speakers and the 4 connections on each speaker.. a +/- for each voice coil
Putting a wire connecting the positive on 1 voice coil to the negative on the other will cause an ohm load increase and make it act like a single 4ohm load
After installing the yellow jumper wire.. taking all the remaining power inputs on the subs and running them all together and do the same with all the negatives.. then plug these 2 wires into the bridged part of your amp..
___________________________________________________________
you just turned 6 2 ohm loads (12) into 3 4ohm loads ... then turned those 3 4ohm loads into 1 4ohm series which was divisable by the number of speakers involved in the series.. 3.. sooooo 4ohm/3=1.333333333 which in real world numbers is more like 1.15
This is how your wiring diagram SHOULD look.... only not a messy ass scribble drawing.. lol..
MAKE SURE YOU ARE JUMPERING FROM THE POSITIVE ON 1 VOICE COIL TO THE NEGATIVE ON THE OTHER.. NOT jumpering from the +vc on one to the -vc on the same voicecoil.. i know this sounds super ******* obvious.. but.. just make sure if youre gonna do it do it right.
