Disclaimer: Links on this page pointing
to Amazon, eBay and other sites may include affiliate code. If you click them and
make a purchase, we may earn a small commission.
i removed the bump stops completely an the bracket is still there but it is not touchin the axle pad im still about 2 inches away from touching the axle pad id say
What are your fender measurements? From what i remember, i had about two inches before the axle hit the bumpstop brakcet before i cut it out. From the pic, it looks even.
yah the djm tahoe 5 inch springs will sit about 1 inch lower than that. the trailblazer 4 inch djm rear drop spring will sit about 1 inch lower in rear but no biggie you just run the belltech 1 inch spacers and you will be set to go.
I have a mcgaughys 3/5 drop in the rear of my 03' done a few days ago and finally drove it today. The rear sits 1-1 1/2" higher than the front after we cranked the keys up some. do the springs have to settle? I have drop shocks.....
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
