3/5 lowering kit
thehoe92
fo sho
The916
he said he got them cut but maybe he was just talking about a notch off the actual bump stop and not the whole bracket
picture of underneath the car where the spring is would help the best :)
03blkhoe
lawton,ok
i removed the bump stops completely an the bracket is still there but it is not touchin the axle pad im still about 2 inches away from touching the axle pad id say
matt14
san leandro,ca
What are your fender measurements? From what i remember, i had about two inches before the axle hit the bumpstop brakcet before i cut it out. From the pic, it looks even.
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
djm rear springs will sit lower or you can go with the trailblazer 4 inch drop spring to bring it dead even with the front.
03blkhoe
lawton,ok
The front from the center of the wheel to the top of the fender is 17 an a half and the back is 19 an a half
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
yah the djm tahoe 5 inch springs will sit about 1 inch lower than that. the trailblazer 4 inch djm rear drop spring will sit about 1 inch lower in rear but no biggie you just run the belltech 1 inch spacers and you will be set to go.
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
no prob the djm springs i can only get by themselves unless you want to buy a complete trailblazer kit everywhere else.
I hooked up with mike there since im the number one seller of their trailblazer kits and he gave me a good deal with djm
Slammedchevy01
I have a mcgaughys 3/5 drop in the rear of my 03' done a few days ago and finally drove it today. The rear sits 1-1 1/2" higher than the front after we cranked the keys up some. do the springs have to settle? I have drop shocks.....
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
ive installed their kits locally many times and its just the way it is. if you want to go lower get the djm 5 inch rear drop springs
swdn25
