305/55R20 pics???
Bigmac18
This is awesome! Exactly what I'm looking for. Thank you sir.
Mind if I ask what your lift is? Spacers on the struts?
2.5" motofab spacers above strut and a .5" spacer below strut. and 2" spring spacers in the rear.
2.5 in the front is really ma, I pushed it another 1/2 inch and will need aftermarket Upper Control Arms soon.
ScrewbenSS
ScrewbenSS
I see! I already have the rought country 2" kit. It puts a 1" spacer below the strut only. So maybe a 1 inch spacer up top and 2 inch on the rear. With some after market upper control arms should do the trick. Thank you again for the info I really appreciate it!
Bigmac18
Just be careful, anything less than 2" on top of the strut will need the bolts trimmed shorter to the thickness of the spacer.
Njoppy
