3rd row seat removal Premier Edit:deck added
Stephen Thompson
Can anyone who has done this tell me if you've brought for vehicle in for service after this was done? Did they ever threaten that this voided the warranty?
Burly Guy
I really liked what you did and instructions were great. I made templates and cut 3/4 plywood with counter sunk holes to fill the no carpet voids. You have to put bolts in holes since they are open to bottom of truck and would let water in. I cut off the studs used to locate the seat belt bracket at 3/4". Then I put in the Weather Tech rear cargo mat. I can put the third row back in if I have a need in 30 minutes.IMG_7881.JPG IMG_7879.JPG IMG_7882.JPG
Rdr854
Northern VA
As a general proposition, I would not think that removal of the third row seat would void the overall vehicle warranty. That said, I would recommend that you look at the OEM upfitter guide for your particular vehicle in order to make sure that your installation is consistent with the OEM recommendations.
This platform is used by state and local governments for special application vehicles in police and fire departments.
BlackYukon
I'm kind of a Retard
The 19' Custom Midnight Edition Tahoe comes with the 3rd row seats deleted and replaced with just a simple carpet. Does anyone know the part # for that carpet?
TahoeAgain
Instead if using hex head bolts to hold the wood panel down, I used flat head bolts and counter sunk them into the panel so they were flush. The head of the bolt was approximately 1 inch so there was plenty of surface hold the panel down firmly.
Laurie McCargar
MT
I really liked what you did and instructions were great. I made templates and cut 3/4 plywood with counter sunk holes to fill the no carpet voids. You have to put bolts in holes since they are open to bottom of truck and would let water in. I cut off the studs used to locate the seat belt bracket at 3/4". Then I put in the Weather Tech rear cargo mat. I can put the third row back in if I have a need in 30 minutes.View attachment 222381 View attachment 222382 View attachment 222383
I am so glad I found this. I want to do this to my 2017 Suburban. I hope the disassembly is similar!
Laurie McCargar
MT
Tools needed:
15mm socket and ratchet
Small screwdriver
Start with removing the accessory tray:
Remove Matt
Remove “thumb” screws
https://www.flickr.com/gp/163893409@N03/13jcz8
https://www.flickr.com/gp/163893409@N03/3fw880
After removing screws simply lift out container
Remove the aft 4 10x1.5mm hex bolts (silver) using 15mm ratchet.
***Raise the seats
Remove 3 access covers and 3 forward retaining bolts
https://www.flickr.com/gp/163893409@N03/Qr2Y70
After bolt remove I replaced the covers
***Lower the seats
Have your screwdriver handy and roll the seat section up
https://www.flickr.com/gp/163893409@N03/WT98d8
Unplug the electrical connection lifting the tab with screwdriver
https://www.flickr.com/gp/163893409@N03/0dhW4N
Your all set! Remove the seat assembly
https://www.flickr.com/gp/163893409@N03/AiJ23r
I will be adding a proper deck with spacers I’ll add to this post
Just remember to bag your bolts and wrap the seats for storage...
For now a weathertech insert works fine
Did you post the deck post somewhere? I am new to this forum and antsy to take my Suburban apart so I can add a deck for a bed on top and storage below. I hope the hex bolts aren't super tight since I don't have anyone helping me.
Tahoe14
Central Fl
If the hex bolts are too tight try a rachet with a longer handle and it will give you more power to break them loose or try a battery powered impact wrench. Good luck. I think it is great that you are willing to tackle this project by yourself.
Laurie McCargar
MT
Has anyone removed the 2 captain seats in 2nd-row new-ish (2017) suburban?
Now that I can see how to remove the 3rd row, I am ready to work on the 2nd row :/
MuleDog
