4 bulb mod for brake/turn lights?
retorq
Kingman AZ
He's just soldering wire from the bright side of the upper bulb to the bright side of the lower bulb ... you don't really need to see where everything goes, get a test light and some wire and do it up yourself. :D
B
bwright81
salt lake city
good call it was pretty easy and a must do mod especially with tinted tails, here is an after shot with dual brake lights and one of the corners, also i have more pics if anybody is interested in doing either
raptorforme93
Tampa, Fl
So it just makes your tails brighter? I will definitely do this if it does since I have really dark tinted tail lights on my hoe
B
bwright81
salt lake city
yes it does, your top bulbs only illuminate for headlight/park and your bottom bulbs do that as well as brake and signal, what this does is illuminate the top bulb for brake and signal also, very simple mod if you have a soldering gun and some wire
86chevyman
Hey where did you get your headlight housings from. I believe i am about to order the same ones. These are the ones.http://www.ebay.com/itm/94-99-GMC-C10-Suburban-Yukon-Black-Housing-Headlight-Corner-Bumper-Lights-8PC-/280765542502?pt=Motors_Car_Truck_Parts_Accessories&fits=Year%3A1999|Make%3AGMC|Model%3AYukon&vxp=mtr&hash=item415eee3066
B
bwright81
salt lake city
---------- Post added at 08:10 PM ---------- Previous post was at 08:07 PM ----------
those headlights are very similar but slightly different i think, i love mine and they have never had any water work its way in, all they need now is some projector retrofits which is a project for spring i think
retorq
Kingman AZ
I love the upper front bulb mod, did mine a while ago, one of the coolest mods I think I did ... :D
Hey do you have bigger pics??
B
bwright81
salt lake city
ok here are better pics, two of the upper corners, before and after brake light pics
the big blue bus
richmond, va
any pics of the wire you added? want to do this to mine. got corner mod and 4 high. i like the little mods that no one would notice unless told but they make it stand out from the rest
tdmcpa
