4 bulb mod for brake/turn lights?
the big blue bus
richmond, va
corner mod is easy. i used stock corners and cut out the socket and got some bulb sockets from junk yard to twist into them. you glu the socket you cut off to the back of the upper corner. you have to drill a hole in for the bulb to stick out. i have pictures if needed
the big blue bus
richmond, va
figured problem with old board was bulb connection there were good the whole time :( wasted money oh well im working on this mod now and should have it done by the weeknd to go along with the upper bulb i added
tdmcpa
