4 Hi mod help
L
lucasbrackins
How to wire up the 4-HI mod.
Ok here we go So i will pull that diode when i get home
L
lucasbrackins
All good, it still works. The real test will be if they are still working tomm afternoon
L
lucasbrackins
Got in the truck to drive to school and same deal?? Flip back to lows and they flash and go out?
---------- Post added at 06:30 AM ---------- Previous post was at 06:21 AM ----------
Startin to get pissed now, i have no clue
L
lucasbrackins
This is the wiring diagram out of the truck out of a Haynes repair manual
The only thing i can figure is the drl relay
L
lucasbrackins
Well hell im lost now when i go from lights to drl i loose them?
SunlitComet
OBS Jedi-Do Good
unknown at this time.
so when you have head switch off and parking brake released you have low beams?
when you turn switch on you again have low beams but marker lights as well correct? and they stay on forever with out issue?
when you go to high all beams are on and marker light as well but sometimes the lows flake out while everything as is on? do they randomly come back on or just die until you do something.
L
lucasbrackins
High and low work fine alone
---------- Post added at 06:18 PM ---------- Previous post was at 06:15 PM ----------
With the key on I have daytime running lights, when I flip the main switch to turn on the headlights I have low beams and marker lights, but when I go to turn off the main switch I lose my daytime running lights. With four high conversion wired in, I go to highbeam and when I flip back to low beam I'll lose my low beams, and they will not come back on until I turn my daytime running lights off as well as my headlights
dirt
