4 wheel selection
03z71chevy
Buford, GA
I had the exact same symptoms as well as mine once putting itself in 4hi while driving. I solved this by doing exactly what SLCHOE suggested. I replaced the sensor in the encoder motor using a new GM part that I found on ebay for around $80. I did this over a year ago and have never had a problem with it.
It is not hard to replace. Here is an excellent step by step write up that I used.
http://www.fullsizechevy.com/forum/...-encoder-motor-sensor-replacement-w-pics.html
C
cooljunk
To update this thread, I finally solved the problem for good. Installed a Transfer Case Motor Encoder Ring. Using this Youtube vid.
Did manage to change it without removing the front driveshaft, a bit of a job. No need to reprogram, it worked fine.
sophielab
