4hi not engaging
FireManDave
My 4 hi will not engage, So far what i do know is that in netural the 4 lo will engage and the light will go solid and i can go back to 2 hi fine with a solid light. But if i try 4 hi, the 4 hi and 4 lo light will flash a couple times then go it will go back to 2 hi. Now when I pull the transfer case fuse, it acts like it resets the transfer case switch cluster and it will go into 4 hi that way but going down the road it will be solid when im on the gas then when i let up sometimes it will flash(not always).
1996 chevy tahoe
350 vortec
push button 4 wheel drive
What do you guys think?
clean454
uhhh dont get stuck is my suggestion! lol jk maybe a bad switch?
"350Vortec"
*Tahoeless, For now*
Bad relay, or bad ground sounds like. I always like my manual type pull bar 4x4 engage on the floor. No electronic bull to deal with.
F
FireManDave
and It works fine this morning now goes in and out of 4 hi just fine. I plan on pulling it into the shop and taking a look at the grounds and to see if i can find the relay.
Thanks
bsamoul
Hoe Enthusiast
Walnut Creek, CA
Mine flashes on 4 hi and low :/
---------- Post added at 03:45 PM ---------- Previous post was at 02:41 PM ----------
do you think that upgrading to the electric actuator would solve my problems?
Landchipper
AL
Time for me to read and learn
I too am hoping to learn from this answer as my 2wd on my 98 with auto 4wd option light is bright until I drive on a bumpy road and then the light goes dim and it feels strange in the front. I will read and watch intently. :Handshake:
