4L60E to a 4L80E
Phone Man
Long Island NY
Ok is this possible or will it be a Frankenstein of a truck? (no pun intended since it is Halloween :)
blueflamed03
Oklahoma
copied off LS1truck.com
Finally finished the 80e conversion. Damn, I need a lift in the worst way, my shoulder blades are raw from crawling around on my back under the truck all day.
What all I had to do to pull the old trans out....
Remove passenger side fender well liner to aid in the process
Disconnect positive lead from battery
Set e-brake and chocked the rear tires
Remove front two O2 sensors for access to exhaust nuts
Remove y-pipe from manifolds and muffler assembly
Unbolt the shift lever from the trans and remove the shift selector switch and set aside
Remove the u-shaped clip holding the shift cable to the bracket and remove cable from bracket
Unbolt fuel lines mount bracket from driver side of case
Unbolt 15mm nut at trans rubber mount on tailhousing. It is inside the access hole in the bottom of the xmember.
Remove four 21mm nuts at crossmember
Put oil catch can under tailhousing and remove driveshaft
Remove trans pan and drain fluid into catch tub. I use a large Rubbermaid so I don't miss a drop.
Put the pan back on.
Remove starter
Remove convertor bolts
Jack up crossmember to take the load off bolts and then remove the 4 bolts
Lower transmission until the oil pan rests on the front xmember. trans xmember will fall off. Remove vent hose from trans xmember.
Use a wood block or plywood to protect the trans pan and jack trans assembly back up so you can remove the exhaust y-pipe assembly.
Lower transmission back down
Remove heat shield on passenger side
Remove speedometer pickup wiring on tailshaft housing
Remove large wiring harness on passenger side of trans behind heat shield by squeezing the sides
Remove trans cooler lines, top is return, bottom pressure side. Slide plastic covers back and take a pick to remove the retainer wires inside the fittings to remove the hoses.
Using a 4 foot long extension and swivel, remove the three 13mm nuts holding the fill tube, vent tube and fuel lines brackets
Jack transmission back up and remove fill/dipstick tube, remove jack
Place transmission or motorcyle type jack under transmission and put light support on the transmission.
Using a 4 foot long extension, remove all the 15mm bellhousing bolts. Lower bolts can be removed with a regular short socket setup.
Remove the transmission assembly and take care to not let the convertor fall off. A bolt into the convertor tab and mechanic's wire or zip tie to the inspection hole will hold it in place.
My 2002 80e has a transgo HD2 kit, vacuum mod kit and PI Vigilante 10" 3500 stall convertor custom built to mount to a standard truck/LS1 flexplate.
Install procedure...
Install convertor and make sure it's seated all the way. Tie it back using mechanics wire so it doesn't slip out. Put bolts in the cover holes and run wire across the convertor lug to hold it in place by wrapping the wire around the bolts.
I have a piece of masonite placed on the ground to slide the trans out or to put it under the truck to prevent scraping up the pan.
A motorcycle jack with plywood on it works good to install the trans. A ratchet straps across from one side of the frame to the other was used to hoist it up high enough to get the jack under that heavy pig. After you get the transmission high enough to get the jack securely under the trans just jack it up to installation height. Getting the trans at the right angle is a little tricky when you're doing it by yourself. Using a ratchet strap from the jack, up and around the tailhousing to pull it to same angle as the engine works well.
Install transmission as normal and check that the convertor has space between the flexplate and the convertor during install.
Tighten all the 15mm bellhousing bolts
Install the vent tube bracket at the top center stud, 13mm nut and vent tube to the transmisson vent. Tube will be the stock rubber hose from the 60e.
Install the fuel hose bracket to the top bolt on the left using one 13mm nut
Jack up transmission to maximum height and install new 80e oil fill tube and secure with the last 13mm nut.
Measure clearance from flexplate to convertor lugs. If greater than 3/16" then place appropriate thickness washers to get correct clearance. Use bolts supplied by convertor manufacturer. Longer bolts will be needed if you have to use washers greater than 1/16". You may have to buy longer bolts and cut/grind to correct length.
Install convertor bolts loosely in all three holes and then tighten after last is installed.
Install starter
Lower transmission, again
Install cooler fitting c-clips
Stretch the bottom cooler line out by removing some of the bends to fit to the front cooler fitting.
The top line is the return line and needs to be cut and a piece of tubing or transmission cooler quality hose needs to be used to extend it to fit into the rear center support return fitting. Installing two clamps per end of hose is suggested when using rubber hose to prevent possible leakage should one come loose. -AN compression fittings can be used along with braided hose rather than cooler hose. In my instance a piece of 3/8" tubing and two compression fittings was used. These compression unions are available at any hardware store. A piece of 3/8" steel fuel line can be used in place of the transmission cooler tubing.
Snap the cooler hoses into the fittings and give a good tug to make sure they're securely fastened and then slide the plastic retainer clips over the cooler fittings
Driveshaft mod...
The worktruck has a steel driveshaft and has 1.188 diameter ujoints caps, 1350s, same as my 80e slip yoke. No puney 1.06 or 1.125 1310/1330 size joints. Installed a new ujoint while swapping the 80e slip yoke onto the old driveshaft.
Crossmember mod...
Modify the xmember by cutting off 5" from each end. Use 4" x 1/4" thick plate 10-1/4" long to move the xmember back to the mount location. It ended up being 5-7/8" that I had to shift the mount toward the rear.
Wiring mods...
Remove K(orange), V(light blue), S(white), T(tan/black) and U(brown) wires from transmission connecter. Move U(brown) wire to the S location.
Front Input Speed Sensor (ISS) is made by using the orand and light blue wires. Add a VSS connector, connect orange to terminal A and light blue to terminal B. Move the low signal wire from pin 45 to location 26 in the TCM harness.
Install the front Input Speed Sensor wiring connection
Install the shift selector switch on the driver side you removed from the 60.
The factory speed sensor can plug back into the 80e tailshaft sensor
PCM/TCM...
Conversion is finished, had to get a 2008 Chevrolet Express 4.8L/4L80e van C2500 TCM tune to get the transmission to shift correctly. There was nothing special done to make the TCM work in the Silverado, just swap them out. The TCM was loaded with a factory tune for an 80e transmission, thanks for the help there Nathan.
Type: Chevy Express (V8) 2008
VIN: 1GCGG25C481106014
TCM...
Segment 1: 24239927
Segment 2: 24235887
Segment 3: 24251658
Segment 4: 24235883
I did not have to buy HPTUNERS licenses for the new tune since its just the TCM. Now I need to learn how to tune these POS E38/T42 PCMs. Without the 80e TCM tune there was no speedo output to the PCM and the tune would not enrichen the fueling when accelerating.
Phone Man
Phone Man
Long Island NY
Ok... Plan "B"... Who can recommend a place on the web or on Long Island NY to get a quality Heavy Duty 4L60E?
blueflamed03
Oklahoma
http://www.finishlinetrans.com/
---------- Post added at 03:44 PM ---------- Previous post was at 03:43 PM ----------
4L60E-4 Street Strip – Level 4Price: $1,950.00 (with core exchange - more »)
Installed Options
TCI Deep Aluminum Pan Kit: $159.00
- 6 A/N Male Cooler Fittings: $25.00
•FLT machined performance pump.
•Media blast case, bell housing, and tail housing to restore a new aluminum finish. Prep case for assembly.
•FLT sleeved input drum
•FLT (billet 6061 aluminum) overrun piston
•FLT beast shell kit w/bearing kit
•8 B/W hi-energy clutches w/koleen steels in 3-4 clutch
•Extra Wide Heavy Duty double caged 29 element sprag
•4L65 low roller clutch
•Transgo HD-2 shift kit
•Corvette servo
•Alto wide 2-4 red lined band with reinforced anchor
•Bushing kit
•New solenoids
•New Internal wire harness
•New GM Spacer plate
•B/W clutches
•Seal & gasket kit
•Filter
•Updated aluminum accumulator pistons
•FLT prepped valvebody with HD 2-3 shift valve modification
•Set end play to FLT specs
•Case cooler fittings
To order now or get more information, please call Finish Line Transmissions at 630-350-7776.
---------- Post added at 03:44 PM ---------- Previous post was at 03:44 PM ----------
[email protected]
95TwinTT
Minnesota
Those instructions make it sound a lot harder than it really is. Most of the items are just part of a normal trans removal and install.
I just moved the cross member back to the empty set of holes in the frame. No need to chop up the cross member.
I also use a separate control for the tranny, so I just had to hook up the laptop and select 4L80 instead of 4L60.
I have found that a stock 4L80 will run circles around a “built” 4L60.
On the other hand, if you don’t have big horsepower, don’t bother going to a 80. :)
steamroller
The South
:word:
The biggest obstacles are driveshaft lengths, the transfer case input gear has a different spline count if yours is 4wd, some minor rewiring, and the PCM programming.
Not everything is covered in here but he has some pics of the 2 side by side and sliding the crossmember back.
http://www.pswired.com/95silverado/performance/4L80rebuild/4L80rebuild.htm
Sctom
