My 2006 Tahoe Z71 5.3 was running fine, but lost oil pressure. It’s been lower than my 02 Tahoe, but it suddenly dropped while idling. I opened it up to replace that stupid O ring at the top of the pickup tube and the oil pump, and decided the timing chain needed to be replaced as well.
I haven’t removed the chain yet, because when I set the #1 piston to TDC on the compression stroke, the timing marks were both at 12:00, not 6:00 on the cam and 12:00 on the crank (pointing at each other) as the manual says they should be. Since the engine was running fine, I’m assuming I should put it back that way, but I don’t know if there’s a reason I should move it 180° to point the marks at each other. Has anyone else found this to be the case?
I’ve only had this truck for about 20k miles and 6 months. My ‘02 is at 554k and needs a rebuild soon, so this is the replacement for now and I don’t have a lot of history on it. The guy I bought it from does specialty engine rebuilding and LS swaps for hot rods but said he had never done anything to this truck other than drain all the fluids as soon as he got it. I don’t have any history prior to that, but it’s in good shape with under 200k so I doubt the timing chain has been done before.
