5.3l flex fuel extended crank
wsteele
Hello everyone I have a 2007 tahoe z71 package and I am having a problem with extended crank. I put a fuel pressure gauge in it and while running it’s at a out 58-60 psi shut it off and it sat at 50 psi ish let it sit for 2hours and it dropped to 10psi then turned key on and jumped back up but had extended crank. But if I let it sit over night it fires right up normal. It dose gave a new fuel pump in it. It did the same thing before the new pump and after the new one it seemed fixed then after about 3 months it’s back . At this point I’m stumped other then maybe a injector stuck and flooding it and when it sits over night by then it’s all evaporated and starts right up. I’m I wrong on this. And if not how do I tell witch injector . Also it dose it on e85 and regular fuel . Oil dose not smell like fuel and is not thinned out .
thanks you in adanved .
It sounds like it may be flooding when it leaks down after shutdown. That might explain the normal start the next cold start, but the long crank when warm.
An injector(s) not shutting off completely could account for the pressure bleed and a flooded warm start. You might try a flood clear procedure when you expect the warm start long crank. If it catches briefly during flood clear, it might be time to take the injectors down for a test.
The bad news is your trims should be off some if the injector is not fully shutting off.
G
Gatto
Can you see what the PCM thinks the engine coolant temp is when it happens?
I will check that when I leave work today as it will more then likely have the extended crank.
G
Gatto
So I did another live data won’t let me post the recording of it but here are pictures idle ,1500rpm 2500rpm and engine off key on.
G
Gatto
Here are the others
wsteele
Nothing extraordinary in the Bank 2 trims. Do the Bank 1 trims look similar?
tom3
I'm not really up to date on the newer stuff, but could it be the fuel pressure regulator leaking back into the intake? Older models used vacuum to adjust pressure once the engine starts.
wsteele
Unfortunately the 07 MY (like a think the last two NBS models) has the fuel pressure regulator in the fuel pump assembly (in the tank), so the older style regulator next to the rail isn’t there.
wlivsey
