D_middlestead
- Joined
- Dec 28, 2014
- Posts
- 12
- Reaction score
- 0
I have a 2007 GMC Yukon that has 108000 miles. Have had issues in the past with oil sending unit this I have replaced 2 times in the last 2 years. Not an expensive fix but a difficult one. Oil pressure has been consistently lower than usual lately but is around 25 psi at idle and normal 40 while driving. Now driving home from store my " service traction control" warning and "service stibiltrax" warning popped up on screen. Car began shifting very hard out of 1 gear into 2 and motor would shake badly while at idle. When driving at about 1500 rpm motor seemed to not shake so bad. A few miles down the road my chech engine light came on solid and then would flash at times. when I got home I read the codes and 3 popped up. 1. P0701 confirmed. 2. P0306 confirmed. 3. P0306 pending. My question to this is why is the second 0306 pending. What does that mean. So. What I have done is a compression test. I had already taken out plugs and all plugs were worn but #6 (problem cylinder) had a little oil on it. I know basic trouble shoot for misfire is change plugs and wires. Possible coil pack if that does not work and last usually a compression test. I did compression check first since already there and had equipment just to make sure. All cylinders accept #6 are between 160 and 170 psi. #6 has 0. I did the check a few time on tgis cylinder just to make sure and once out of 4 it came to 85 psi. My question is. What's next. Am I screwed. Is it shop time or it there something simple that could be happening. Any thoughts would've great. Thanks.
