$5,540 up-charge for the Diesel
P
Protect1989
What i’m saying maybe they’re adding packages as part of the diesel option.
Funny enough it’s the exact opposite. You can’t get most of the packages with the diesel including the air suspension or tech package.
Build out a 3.0 diesel and try adding any package, it makes you go back to a 5.3
pa31p
In that case. you can burn a lotta gasolina for $5K. i’d pick the 6.2
olyelr
Elk Rapids, MI
I guess thats better than the $12k cost for the cummins in the ram trucks.
Last time i played around with building a gm the diesel was cheaper than the 6.2, but that was a while ago.
Padraig
WOW! When I bought my 2023 Suburban LS, the Diesel was just under a $1,000 option. That was a no brainier.
Padraig
mplunk
Adding the diesel force adds the Comfort Package and advanced trailering package vs both of those being an option with the 5.3. That's $2,725 of the increase, plus it adds the power second row bench seat for $370. So $3,095 are added packages and the diesel itself is a $2,445 up charge. Still a big price difference but not as bad as it seems.
I may have missed something else that gets added as well
P
Protect1989
Good to know. Annoyingly you cant add the air ride suspension or the tech package for the diesel (dont know why)
DuraYuk
Playing around with the 2025 build configurator and it shows a $5,540 up charge for the diesel engine on the Z71.
On the build calculator for a Silverado ZR2, there is only a $1,965 up charge to the diesel.
Do we think the $5,540 Diesel motor premium is legit or will that come down in time? When using a fuel calculator, it would take over 7 years to recoup that cost compared to the 5.3!
In the refresh the diesels are being paired with super cruise...as the only way they can be optioned the price increase is from that pairing
DaveL
I think when you change it to the diesel, they add a bunch of packages at the exact same time.
If you look at the diesel on the high country, it is not that much more because the high country already has a bunch of those packages built into the price.
I'm waiting for some to hit the lot to see what the final price is.
dukecharmary
I did a build at the dealer last month for a denali duramax. This option added supercruise tech package. But said the system would not accept order and probably be March
Shadfrmdabull
