Very well put! That is exactly what the inside of my intake looked like! Had it not been for pulling the throttle body blade out to cut off the restrictor, I would not have known how horrible it was, and therefore may not have made the effort to clean it. I am definitely buying a block-off plate, and getting mine tuned out now! If I just throw the block off plate on it, and order my tune in a couple months, will it affect performance when the PCM throws the code? Also, will Seafoam through the brake booster hose clean out this kind of crap?
Thank you for reading my post.
I will start with saying, seafoam knocks down the build up in the vacuum lines. It works well for that purpose and that's about it. Also it works well to clean the pcv valve. Just soak it for an hour and then blast it with brake cleaner to finish it up(also brake cleaner dries it faster so you can reassemble quickly).
I don't recommend using to much through your intake or booster line, as if the picture is any point of reference. You wouldn't want to use seafoam and break all that loose. I wouldn't want all that dropping further into the runners or building up on valves and cylinders. Just pull the top off the intake and clean it manually, it will be more effective. Especially since the second that build up gets wet it turns into the consistency of roofing tar and just as sticky.
I don't ever use seafoam in my fuel either. I am not sure about LA, but up in the north where i am. The amount of ethanol in the fuel from the pump renders seafoam pointless. Seafoam dries out water from fuel and ethanol serves the same purpose. So; if your pumps say 10% or more ethanol, don't put it in your fuel.
As for dumping it in with your oil, PLEASE DON"T DO THIS. It doesn't have any sufficient lubricating properties. It is like pouring water into the engine and expecting it not to prematurely wear bearings.
If you want to clean your engines internals without putting extra wear or strain on it. Replace one quart of oil with ATF trans fluid, and run it for 500-600 miles. It has great lubricating properties, high detergent levels and is thick enough to push out crap in oil passages without causing to much pressure or becoming to thin to let metal on metal contact.
As far as check engine light, I am not sure if it will turn yours on or not. That is fully dependent on the vehicle, but in the case of my truck. I have not had any performance losses and my truck idles so much smoother now. If you can tune it out go for it, if you get time to do so, strip out the connector and wiring to the EGR valve. It will clean up the engine bay and remove a random electrical plug hanging from the engine area.
If you need an example, my 5.7L vortec engine has 237,000 miles on it as of 3 days ago. It has 42lbs cold start oil pressure and 18-20lbs oil pressure hot dependent on idle speed. I flushed my engine 3 times in a row to thoroughly clean the motor, cooler and lines. After 3,000miles i religiously change my oil and it comes out clean. Yes i switched to synthetic and it is partially a waste to change so early, but i also don't like my oil to break down and lose its ability to do its duty. Between heat cycles and small amounts of fuel mixing. Oil will break down and not be as efficient as it once was.
My compression if anyone is interested, all in the 145-165 range. With a 6lb spread lowest being 149 to highest at 155. Pretty respectable numbers for a 237k motor.
As soon as this one runs off its last leg, i will be dropping in a Vortec motor turned into a 383 Stroker.
