6.0L Fuel pump?
OR VietVet
GMT800 SUV/Trucks
Military
Willamette Valley
OMG :(
I watched the A1 auto tutorial to drop the tank. I'm putting it back on now. However, they did it the HARDEST way possible.
You can disconnect the EVAP canister and valve. Then the fuel lines. Slowly lower the tank, and disconnect the pump harness.
Then it comes off without dismantling all these evap lines. They go with the tank. What a mess. Trying to figure out how all these evap lines were routed.
That is why, when I recommend a member to view you tube, I tell them to watch several videos because they typically are never alike.
Fless
Super Moderator
Elev 5,280
And read up here. I posted several times about leaving the evap lines on. I learned the first time I dropped the tank that they can all stay on, at least on the FF tanks.
Matthew Jeschke
Matthew Jeschke
Sahuarita, Arizona
I see your message now... posted earlier. Thanks!
I kid you not I wrestled the tank under the trunk trying to snap back in the fuel lines on those retainers with it in the truck. After about 30 minutes I gave up and lowered the tank. I quickly saw if I had disconnected only 3 quick disconnects (evap, return, and high pressure) I'd have been able to lower the tank with the lines on it. There's disconnects right on the chassis and evap canister.
I put the lines on the tank... then raised it back up and clipped them into the chassis / hard lines & evap. Was a breeze. Took minutes. I cannot believe A1 auto tutorial did it another way. Their tutorials are awesome but that one they very much got wrong haha
Fless
Super Moderator
Elev 5,280
I left the fuel lines on the truck and just disconnected them from the pump, and snapped them out of their retainers on top of the tank. The splice connectors at the front of the tank, by the crossmember, were too difficult to get apart with the tank so close and it was easier to leave them on the truck.
Matthew Jeschke
Matthew Jeschke
Sahuarita, Arizona
I watched a handful of tutorials. Several guys took the truck bed off. Others cut holes in their floors. People are crazy haha. In the end I found out there's a very simple way to disconnect three lines from chassis. the harness and it practically falls off on it's own.
Matthew Jeschke
Matthew Jeschke
Sahuarita, Arizona
Why don't they use a Quick disconnect like on the fuel rail? Those stupid plastic tabs are a PITA. When I did things the second time I had to find them blind as there's no way to see where the tank lines attach to the chassis without a mirror, camera, or something.
OR VietVet
GMT800 SUV/Trucks
Military
Willamette Valley
I cringe severely every time I see a thread or response about cutting a hole for access. Lazy and stupid IMO.
Fless
Super Moderator
Elev 5,280
The dark clip is to hold a couple of hoses together, maybe some evap lines? And the light one, it looks like it's for holding multiple lines (brake?), but I don't recall having either one of those on my truck. Well, the black style one in other places, not with the tank lines.
OR VietVet
GMT800 SUV/Trucks
Military
Willamette Valley
I have seen the dark one under the hood before, but not on mine. The light one is held in place by the little hat stud and holds a series of same size lines all in a row so they are not flapping around. I don't remember ever seeing it before, though. Properly attached and located zip ties can accomplish the same thing.
Now that I think about it, the dark one I have seen under the hood of foreign vehicles. They can be used under the hood or in other places on American rigs though.
Rome58
