Your engine is the L94. It has VVT and AFM. The VVT system is very reliable and durable. However, a small but unknown percentage of those engines will have problems with the AFM system that manifests as a stuck lifter and a loud tick with a misfire. While it won’t likely last more than a few hundred miles that way, it’s unlikely to strand you on the side of the road. You can have the AFM system shut off with a custom tune, and the lifters will likely last many more miles by no longer needing to switch states and behaving like standard non-afm lifters.I have a 2011 Yukon 6.2 and i am looking at rebuilding my engine. It has 200k miles. Would you go ahead and rebuild? Or wait for it to go and then rebuild? Daily driver.
Maybe you should get a used motor oil analysis, compression and leakdown tests, and any other mechanical tests that would show how well / how badly your engine is aging.I have a 2011 Yukon 6.2L (L94) and am looking at rebuilding my 200K mile engine.
