6" rear lowering springs
tony4143
Will I rub on 26's?? With the 6" drop??? 295-30's??
NORCAL SS
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
on 26s you will need the spohn rear bar kit to recenter the entire rear end to make it sit right with this kit.
NORCAL SS
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
springs will be made. 8-10 weeks out
tony4143
Ok cool. So can you pm me a price on the complete kit with everything I will need?? Thanks
-Tony
NORCAL SS
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
if your going to run 26s you will need 295 25 26 with this set up.
tony4143
^^^ ok. You don't think the 295/30/26 will work?? Or should I just do the 5.5 in the rear instead ??
NORCAL SS
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
if you do a 5+ drop and a 295 30 26 you will need to get the spohn panhard bar to recenter the rear end at least. Also i would look into the upper/lower spohns because on that low of a drop the rear tires get pushed way to the front and can rub bad.
Knobz
Santa Cruz, CA
Hey dude. I have 26's on my truck (there's pics in the beginning of the thread) and I'm running a 255/30/26 for tires and I have no rubbing in the back but then again I have the whole Spohn kit in the rear. And I wouldn't go without it either.
