6hi mod
aidandj
Portland, Oregon
Is there any way to do a 6hi mod (fogs, lows, highs) on the OBS trucks? I cant even find instructions for the 4hi mod for OBS trucks.
ADJ
SunlitComet
OBS Jedi-Do Good
unknown at this time.
Actually you would do a 4-hi mod and make sure your fogs are not disabled in the process therefore having 6-hi mod. Many people her have done that. Going to do the 4 headlight mod soon after I fix my engine. Will add more light later. I bought a $28 relay kit from painless performance which has all the needed components. What year is yours?
SunlitComet
OBS Jedi-Do Good
Thanks for clarifying. In that case I can come up with the diagrams for the 99's
There was one member 99YUK I remember here who had a 4 high for a 99. The link is
http://www.tahoeyukonforum.com/forum/showthread.php?t=19936
Send him a message and he can give you all the info on what he did. I know he made some changes to it lately. I will have to look at my diagrams to come up with a fix to do the fogs too.
99Yuk
Northern Ontario, Canada
I made up another one of my famous 'art' drawings to show how to add OBS Limited Fogs to make a 6-hi.
It needs another diode from the High beam light green wire to the fogs purple wire. Point the end of the diode with the band towards the purple.
If you really wanted to, you could add a relay kit at that point. I'd run it like this first to see how it goes though.
GL!
Monstar_est87
City of Angeles
Ehhhmmm... Please allow me to shed some sunlit on this... It sounds like ur highs R on... Thats the only way the fog lights will shut off unless u do so with the fog light switch... Im interested in a 6-hi mod as well... Im not even sure if a 4-hi mod would some how disable the fog lights...
aidandj
aidandj
Portland, Oregon
Thanks a bunch 99Yuk I'm going to take a look at it today and see how it goes. I'm planning on running 6k lows 3k fots, and philips xtreme power highs. If I cant figure it out are there any commercial kits i could buy to do this? I'm relatively new at car electronics.
Monstar_est87, currently when I turn on the highs the fogs turn off. I want to be able to have all 6 light up at the same time.
kendrick newborn
