9.5SF Swap
mattt
When you say 14 bolt are you talking a full float axle, I doubt it, or the semi float axle? If is semi float, I would grab it for future use or @Dantheman1540 will grab it from you. The 14 bolt full float would be too extreme an axle for that vehicle but others here will chime in. By the way, you can get your own locker from Yukon Gear and be set.
Not talking about a full float axle, the FF axle is only offered in 8 lug and all Escalades are 6 lug which is the requisite semi-float. Thanks!
GMT800 SUV/Trucks
I know it's an 8 lug. I used to own a rig with one in it. But, I had to ask so it was completely clear to me.
fasteddy
Dan...
You need this.
Its unbreakable...and it looks really cool.
Moser!
GMT800 SUV/Trucks
Dan...
You need this.
Moser!
Check your credit limit on two c/c before ordering this axle. I have heard of them and seen one in a drag rig once about 4 years ago. Quality costs a bunch but you will get your money's worth.
Dantheman1540
Dantheman1540
Sugar Loaf Mountain
So I have now seen another GMT800 14 bolt rear axle. It's in another 2wd 6.0 Escalade that recently showed up in my local LKQ yard. This one is still complete as of yesterday. Tempting to grab it for future use when my 330k miles 10 bolt dies, maybe after the 6.0 swap. I did confirm it's the right 3.73 ratio that my Tahoe has (GT4), but no G80 in it. It would run me about $350 to get it out the gate there, don't need it now, but may in the future if/when the factory 10 bolt rear gives up the ghost. What's anyone have to say, keep the 10 bolt, or swap in the 14 bolt? Any downside to changing to a 14 bolt?
So I've now seen a 14 bolt rear axle in a 2005 and 2006 Escalade 2wd w/ 6.0. I wonder if GM used it in 2004-earlier 2wd Esky's as well...time will tell.
Anyone seen this special edition on a 2005 Escalade before? I searched and came up with nothing. The lettering is on the driver's side of the rear hatch and appears to be factory. I can't find anthing on it though. "RCA" Hi-Fi Edition???? LOL!
View attachment 276984 View attachment 276985 View attachment 276986
Theres the RPO code AXN so it's factory like you suspected! Nice find I'd grab it and save for a truetrac or other quality posi. It will be much cheaper to have a posi installed if you take the entire axle assembly to a shop rather than have them work with it in the truck. Or find a g80 online used and slap it in cheap, I am still pretty impressed at how the G80 does on-road and off, My only complaint is it doesn't like to slide.
Never seen that edition might be some after-market crap.
Another thought is to check LKQ and see how much a similar mile NNBS 9.5sf 14B would cost with a G80 already. Might be able to get one delivered to your door with a locker and much younger seals for just a hair over $350, I paid $440 or something close to that for mine with 130k.
I've actually been secretly looking for one to prep for my buddy's 408 Denali. It has a "Built" 10bolt but its only a matter of time before it dies with the way he drives.
Dantheman1540
Dantheman1540
Sugar Loaf Mountain
Dan...
You need this.
Moser!
I'm super happy with the 14b in the Tahoe it takes some serious abuse and even the G80 has yet to let me down. I do wish I would have bought a fabbed housing 9" or 10" for my Silverado though. Building a 90s HD 9.5sf 14B (Beefier than the AXN 9.5sf) has been more expensive than I anticipated and I could have probably called someone like RUffSTuff Specialties and had them build me one of their axles for the same amount or less. Moser is just crazy expensive although awesome!
fasteddy
It was like $1200. I don't know how much to finish it off......and brakes are extra, LOL.
Everytime I get a rear end rebuilt that's about what it is....$1200....And I think mine needs to be checked as I hear a slight clunk from the rear passenger side on some shifts.
But that Moser looks really cool.
fasteddy
That one looks tough too!
Fabbed rear ends look so cool.
And don't you hate that?
You make a decision on an assembly because it seems adequate and less money. Then when you're done you realize the better one was actually a better decision.
I've done that many times....LOL
Dantheman1540
Dantheman1540
Sugar Loaf Mountain
Yeah, that's $1,200 for just the housing not the axle shafts, ring and pinion, posi unit, 3rd member, brakes, parking brake, or all of the shock and spring mounts. Shit gets expensive quick! I'm about $700in on my 14b for my Silverado and it needs another $2kish.
S33k3r
Dallas, Texas
You might look at a G86, which is the limited slip differential. I've got one in my Suburban, and one in my Silverado; my daughter's Sierra Denali has a G80. The G86 is *much* smoother.
WindyCityDenali
