BREAKING: GM is officially recalling the L87
fredtufts
Been watching this for almost 8 hours today.
Still not convinced it is not a late April Fools joke or someone testing their Abode skills.
Nothing on the NHTSA web site at this point in time.
NOTICE the oil shown in the picture, it is NOT DEXOS Approved!!! But ask me what I am running in my engine!!! If has a decent high Moly content.
I have been saying since day 1 to dump the 0W20 oil. My truck had it for only 500 miles, then went to "real" oil!
0W20 is almost fine until too many remote starts and idle warm ups contaminates the fuel to the point you are lubricating with a solvent rather than oil.
The 6.2l behaves like a Diesel and with the AFM trying to turn the rotating mass with a single cylinder, what do you expect.
We will see what pans out over the next few days if this is real or someone having fun.
Want your 6.2l to live long, do not use 0W20 oil and change the oil at the 50% OLM. DO NOT WARM the engine up at idle, it takes the engine oil almost 30 minutes of DRIVING to get up to temperature below 40F ambient.
Question: What do you mean "DO NOT WARM the engine up at idle"? I thought it helps the engine to turn it on for a minute or two and let it idle in Park (no revving of the engine) before you engage it in Drive. Please clarify your recommendation and the reason.
Stbentoak
Our mechanics say that the 3.0 diesel from GM is very complicated. Yes, it is reliable compared to 6.2, but it will be a real headache for owners in the post-warranty period. And 6.2 is easy to repair, even in Russia they know how to fix it in almost every average city)
An in line 6 diesel is about the most simple, common, dependable and recreated diesel engine ever made. I believe the fundamentals of the engine are rock solid, it's all the junk that they have hung on it that make it let's say..... less than bulletproof. The only really known issues with this engine are the coolant control valve which is another under engineered/mis engineered part made from plastic, and the crank no start issue which was back in 2020 that was fixed by a software update. And of course, the 10-speed transmission recall which affects us all.
To be sure I'm sure there's some of them out there that have failed for some catastrophic reason, but you don't hear of any widespread or "Recall" level issues or people being stranded besides the road by the hundreds or thousands. For as many people that have reported on here about petrol problems,AFM DFM,Lifters..etc. and replacement engines, there's probably thousands more out there...maybe 10's of thousands... who are just riding it through and may not even know this forum, or others exist....
Also, a pretty fair share of these 3.0 owners are not really worried about the post warranty and don't keep these vehicles much longer than the six/100...Me included...
Also here is a copy of 2 consecutive oil analyses on a 3.0 @13K miles and 18K miles with DexosD 0W-20. Appx 5600 miles on each test specimen. Both of them less than 1/2 of 1 Percent fuel dilution.... and still plenty of life left in oil....
fredtufts
So lets watch this entire mess unfolds.
Are ONLY the 2021-2024 that are UNSOLD recalled?
What about all the 2021-2024 on the road? Maybe GM brokered a deal where they only will provide an oil fill cap, an adhesive note for the Owners Manual for the 2021-2024 models on the road, not even a free oil change to 0W40.
2025 Owners, GOOD LUCK!
Not all the rest of the owners use the same oil or drive or operate the vehicles under the same conditions.
The SINGLE BIGGEST threat to these engines is how the TCM is programmed to pull max torque at very low RPM's on the highway. How many of these engines failed at 70 MPH on the highway? Most of them.
The next BIGGEST THREAT is fuel dilution of the engine oil. Too many short drives in cold temps, too much use of the Remote Start to warm the engines up, too much engine idling for warm up from cold start. Too long between oil changes, sure follow the OLM, but you are a FOOL. Change the oil when the OLM hits 50%.
EVERY light duty and heavy truck on the road is in jeopardy of engine failures if they continue to use 0W20. Disable the Auto Stop/Start, disable the DFM. Then you are hopefully have something reliable. Otherwise you are gambling.
The NEXT GM fiasco unfolding is the valve body problems with 10 speed transmissions.
Just search my user name, you will find more than you care to read about the engine and valve body problems!
I am a newbie to engine discussions. My '24 Yukon Denali engine failed with just 13K miles for this connecting rod/crankshaft issue, and my engine is being replaced after waiting 5 weeks for a new engine. Could you please clarify your recommendations:
- is using the Remote Start and "idling for warm up from cold start" bad for the vehicle? Are you recommending to start and and put in gear immediately?
- I think I have the option of disabling the Auto Stop/Start, but how do you disable the DFM?
Thank you for your guidance.
jfoj
Do not warm the engine up at idle. Start the engine, allow the RPM to drop to normal idle speed and then drive the vehicle.
See if this is self explanatory. The lower horizontal axis is in Seconds.
jfoj
The ENTIRE problem with the 6.2l is how the TCM (Transmission Control Module) puts the engine under 70%-100% load at 1500-1700 RPM. The engine is being "lugged" which puts massive strain on the engine bearings. Then add the stupid DFM which is having as few as 1 cylinder turning the entire engine rotating mass. Then add the fact the oil Spec is 0W20 and then once fuel dilutes the oil, you have nothing left other than a solvent to lubricate the engine. Just search my user name, I have a bunch of graphs that show everything from transmission behavior, engine knock under load, engine loading and more.
See the post above which graphs out the difference of a 15 minute idle vs driving the vehicle. Start the engine, allow the engine RPM to come down to the typical idle speed then drive the car normally. Try not to make multiple short trips, try not to drive 10-15 minutes and shut the engine off and allow it to cool down. Just look how long it take the engine oil to warm up in these V8's. Part of the issue is there is a lot of oil. Even with the oil cooler in the radiator, once the thermostat opens you still are struggling to get the oil heated up.
For those that have 2024 models, I recommend the Range DFM disabler, it disables the Auto Stop/Start and DFM when driving. The lifters do appear to collapse under DFCO (Decel with Fuel Cut Off) not so much of an issue IMHO, at least you are activating the lifters sometimes to flush fresh oil in them. Pretty easy DIY to installed, out of the way and it appears to work fine. Another option is to drive in L9 up to 55 MPH, L8-L10 are all overdrive ratios anyway. But for highway cruising I would put it in 10th gear at that point.
jfoj
You don't have many miles on your truck. I was hoping that you had 60,000 miles on it and that it was holding steady. At only 6000K, it's tough to say whether everything you're doing/not doing is "working," or if it's just a matter of time (miles) before things go south.
I'm crossing my fingers.
Doing everything on my end to hopefully not becoming a victim of this mess. Interesting that the article about why the 2025 models were not recalled indicated "A series of crankshaft and connecting rod manufacturing improvements implemented on or before June 1st, 2024, addressed contamination and quality issues."
What the hell does that mean?? Contamination and Quality issues?
Anyway, my engine was produced on July 15, 2024 so hopefully my engine may have benefitted from any changes made?? Maybe my 2024 will not be included in the recall, we shall see.
Only time will tell if the change to 0W40 will save any existing engines on the road and if the 2025's running 0W20 will not end up failing like the prior years.
rmsnickers
Really sorry to hear about everyone's misfortune with the 6.2L; I had a deposit at two dealers for one of these but GM never honored the build and I got my money back. Picked up a new '23 Tahoe with the 5.3L and still wondering if there's much concern about these engines with the 0W-20 and DFM if I'm occasionally towing near max limit and live in the pacific nw?
I was thinking of picking up the Carbyte DFM/auto stop disabler (i see Range mentioned in this thread) but I want to be sure there's no impact to warranty running one of these in my rig.
GMT800 SUV/Trucks
So, if in the PNW, must be worried about towing in the passes at max limit.
I know that the new ones have all the bells and whistles and creature comforts and may be the "cat's meow" to drive as a rental, when I know it is not mine and not making payments with the crap in the back of my mind about DFM. But each day I read and feel even better about my GMT800's.
With, I have to say this, the most comfortable seats GM ever made.
GMCChevy
It looks like 2013/2014 was the switch over to 0W-20. While that is a very thin oil it seems like the switch to thicker oil is a band aid to get the engines with defective parts past the warranty period. There's a lot of years of vehicles with a lot of problem free miles on them running 0W-20 to put the blame on oil.
Roller lifters have been around for several decades with no problems in various applications. They were even reliable in the early iterations of the variable cylinder applications. It seems like for both GM and Chrysler it's when they took it to the next level that they started having problems.
It's pretty sad when this push for ultimate fuel mileage and emissions can f!*k up what were once reliable drivetrains so badly.
dcobbs17
