96 Tahoe 2 dr.Oxygen Sensors issue
crows feet
Elberton Georgia
i have a 95 yukon 2dr 5.7 i have one wire on o2 on the exhaust pipe before cat......never changed get ses code abought 20 min into ride,dailey
retorq
Kingman AZ
I wonder when the switch over was ... maybe the ones built later have the 3 wire or something like that.
T
theghoul
so.cal
Ok, heres some pics of 1 of my 02's...the easiest one to access.
Its the pre cat on drivers side...plain as day.
heres the connector from the harness
heres the connector from the sensor ( 1 wire )
heres how it sits in the engine.
any ideas?
clearly they are 1 wire & clearly its a '96!
still not sure what t do.
BTW. the pass. side pre cat 02 looks different & the connector is still 1 wire, but cant figure out how to un connect the connector. its directly attached to the 02 form the harness...IE: not a wire from end of 02 to another wire into the harness. almost like a spark plug.
Its also way lower on the manifold then the drivers side...
SunlitComet
OBS Jedi-Do Good
unknown at this time.
Dude :wtf: Ugh, the last picture is the Temp gauge sensor and that it's connector as well
---------- Post added at 08:17 PM ---------- Previous post was at 08:17 PM ----------
Sorry but clearly you seem to be in the plain as wrong area.:imo:
---------- Post added at 08:29 PM ---------- Previous post was at 08:17 PM ----------
The oxygen sensors are mounted on the exhaust pipes downstream of the manifolds before and after the catalytic converters. Not between manifold ports or on the manifolds themselves on the vehicles.
T
theghoul
so.cal
No wonder it didnt look right!
:emotions122:
I know where the ones on the pipe are...I guess those are the ups & the downs are further back...Thanks for pointing that out!
oldsalt
In that last picture make sure that wire doesn't lay on that manifold.
Zcharysch
