96 transmission interchange
SunlitComet
OBS Jedi-Do Good
unknown at this time.
Scooby it is possible but the tail piece and yoke have to be changed for other parts as well as the vehicle speed sensor is relocated as well. I dont think the converter has to be messed with but I did not looked that up to verify.
lummy
that's correct, in order to use a 2wd trans in a 4x4, you need to change the output shaft and tail housing. To replace the output shaft, you basically have to dissasemble the trans.
I'd keep looking for a 4wd trans
S
scooby30909
Ive found a 4 wheel drive 4l60 from a 2000 Trailblazer. Does anyone know if this will work in mine?
jfloare
