97 tahoe 5 speed swap
87carl
87carl
If everything goes according to plan I will pull the axle bumper and tail lights off the z71 and cut the drivers side of its frame the rest of the way we're it's cracked and remove the entire back half off that truck tomorrow.
Has anyone ever seen anything about someone shoving an 80s single cab shortbed truck frame under a 90s tahoe? I am tempted to try it because it will give me a straight axle it will fix all the frame rust issues I have. The wheel base is the same and motor tranny mounts will line up perfectly drive shafts can be used. Only issue I can see is transfer case is passenger side drop so I would have to use the np208 out of an 80s truck but question is can I use the 32 spline input shaft from the z71 transfer case in an 80s transfer case? Also would have to figure out something with the fuel tank body mounts can probably be cut from the Tahoe frame and welded to the 80s frame. I am trying to decide if I should try to do that or keep patching the rust on the Tahoe frame? I know were an 80s single cab shortbed parts truck is sitting just don't know if I have enough money to buy it and don't know if I should try to do it? Spent today loading scrap in my dodge I will take that in in the morning see what I get for it then maybe go see what they would want for the 80s truck.
87carl
87carl
They want 600 firm for the 80s truck forgot to ask what year. It's got a running 350 engine no transmission no fenders doors bed or hood but I won't need any of that I just need the frame axles suspension and drive shafts transfer case and probably steering box could probably get 300 back selling its motor but idk that's more money than I have rite now and will have to sell a bunch of parts to get that much so I don't know. Tempted but not sure if I should. I will take measurements off the Tahoe frame tomorrow then go look at the 80s truck and measure it's frame.
87carl
87carl
Weather has been ****** snowy windy and freezing so haven't been able to do much but I started pulling small parts off the inside of the z71 today. In hooked the shifter almost got the 4wd shifter out but the bottom bolt is being stubborn turns easy most of the way but locks up tight when it's almost all the way out. I left it to soak in pb blaster then pulled dash bezel and gauge cluster then the steering column started pulling the clutch pedal out but there's one bolt that is being blocked by the wiring harness and still trying to figure out how to unhook the harness so I can move it and get that bolt out not much progress but it's atleast 's start. didn't get any pictures using the phone as a flashlight to see under the dash killed the battery.
87carl
87carl
Can't wait till warm weather so I can get more done on this project. Hopefully the weather idiots are right and next week will be in the 60s. Till then I keep doing little things on it. Changed the computer to the z71s computer changed the gauge cluster so it no longer says prnd321. And changed the steering column. Also removed the electric 4wd buttons from the dash
Ignore the lines in the picture my phone does that when battery gets low.
After I changed the computer and gauge cluster I started it and let it run for a while before I changed the column. Only thing I did after that is change the column. After I changed the column it won't start it's got power to everything and everything else works but it won't crank over. My best guess is there was a safety switch in the old column that used to tell it the truck is in Park or neutral to let it crank. And by switching columns it's not getting that signal? Does that make sense or could it be something else? If that is the problem should I figure out what wires are causing it to do that and hook them to the clutch pedal switch or neutral safety switch? The automatic steering column had a little box with a rod that connected it to the shifter and had two wires that go into the main plug. Is that the park/neutral safety switch or the reverse light switch?
87carl
87carl
And I know it is filthy I will clean itit when I am done swapping everything
87carl
87carl
Oh and most of the cut wires on the dash were either on the steering column or were on a trailer brake controller that's being removed this tahoe will never need to pull a trailer that's what my truck is for. The rest are splices tied on the main start wires looks like some previous owner put a remote start in it and later cut it back off. So at least the wiring ain't as bad as I thought. Swapping columns fixed more than half of the cut wires.
bluex
That's an nv3500 trans in your pickup. No half ton came factory with a 4500 I believe. The 3500 should be plenty for a daily driver.
xanatost
Lafayette, La.
Is any the dash in good shape on the parts truck? If so would you be willing to sell it? I'm looking for a good dash because mine is all cracked up. Good progress so far. Keep the post and pics comming. I'm starting to get parts for my hoe when I change her over to manually transmission.
87carl
87carl
From what I read online You could special order the nv4500 in a half ton but not many got it. So I figured this was probably the nv3500. Couple days ago I looked under a friend's Truck I know has a nv3500 and it look identical to mine verifying mine is the nv3500. And ya they are plenty strong enough for what I will do with this tahoe. My friend beats the piss out of his truck and that nv3500 has held up. I won't be off roading the Tahoe or hauling heavy loads. My dodge does all that. The Tahoe is just for regular driving with the family it's hard to fit 2 carseat and 2 big dogs in our subaru or the dodge.
The parts trucks dash is cracked thru the defrost vents and I used it's radio/cluster bezel to replace the broken one that was on my hoe. If you do a manual transmission conversion I strongly recommend buying a complete parts truck buying it peice by peice gets expensive quick. I paid 400 for my parts truck and should be able to sell its motor for 500 and sell the Tahoe auto trans for another 300 or 400 axles for another 200 and sell other parts and end up completely covering the cost of the swap plus put a little extra in my pocket. Plus it's alot easier to go back to the parts truck for more parts if it's ten feet away rather than 20 miles away at a yard.
Most of it is pretty simple just unbolt automatic junk and bolt in new parts. Hardest parts so far is getting to the one bolt on the clutch petal bracket. Stupid wiring harness and everything else is in the way. Other hard part atleast for me is the electrical stuff. I will keep posting pics and details as I figure it out and get it done. Hopefully we get warm weather next week so I can at least get the manual Trans in the Tahoe and can start to figure out wiring.
bruh2125
