97 tahoe 5 speed swap
87carl
87carl
I already have the gauge cluster changed so it no longer says prnd321 :) and I have the column changed so I don't have any peices of the auto shifter I just left to get a hole saw and torch when I get back I will pull the clutch pedal wires out of the z71s harness see were they go I will also test the pedal switch see if the wires are connected with the pedal down or up. And then go from there
87carl
87carl
It was dark by the time we got home so I wasn't able to trace the wires on the z71 yet.
Dneel81
I found and read your thread. On page 1 sunlitcomit said to connect the purple wires on the clutch pedal switch to the purple wires from the 4l60e transmissions range selector? Were those wires in the 4 pin connector or in the 7 pin connector that has the reverse wires and the yellow and purple start wires? If those are the wires you hooked to the clutch pedal for start safety wires did you have to hook the yellow and purple wires from the 7 pin connector together? Did you hook anything to the purple with white stripe wires? And did you wire anything to the clutch pedal for cruise control?
87carl
87carl
Ok I figured it out the pinout I posted the other day was right on wire functions but not the colors and that is what was confusing me along with the fact alot of threads say the start wires are heavy gauge wires. They aren't. I just spent the last hour reading wore diagrams testing the wires on the range switch and testing the wires on the clutch switch. Wiring goes exactly how I thought it did the two wires in pins g and e on the 7 pin connector which on this truck are both purple get hooked to the lower two wires on the clutch position switch and the upper wires get hooked to the purple wire on the brake pedal switch. The green wire from pin e on 4l60e range switch and the pink wire from pin c on the range switch go to the reverse light plug. That plus swapping transfer case harnesses and switching connectors for the speed sensor is all the wiring I have to do for this swap. Not bad now I just got to get it done.
87carl
87carl
Normally u joints are an easy job but not this time we spent several hours with a torch and a mini 10lb sledge hammer trying to get the old u joints out of the z71s driveshafts so I could put new u joints in and get them ready for the hoe but even after finally getting them all out it wasn't done being a pain in the ass. one of the new u joints needle bearings would not stay in place and kept falling over in the cap plus the seals wouldn't stay in the cap. It looks like that one was a return that they gave me. because the rest of the u joints were neatly wrapped in paper inside the box the problem one wasn't. I was getting very frustrated by that point and ended up bending a couple needle bearings and ripping a one of the seals on that u joint. so I got to buy another one atleast I got 3 u joints changed lol not a productive day
Dneel81
OKC
Sorry for not getting back to you about the wires. Haven't slept much in the last 2 days. Obviously you figured it out.
Glad to eye you're making good progress.
87carl
87carl
Slowly making progress. It's been raining today so I didn't get to work on it. But I forgot to post what I did yesterday I got all the holes cut and drilled for the pedal master cylinder and both shifters. And 4wd shifter is installed. And I discovered why the blend door actuator don't work. It's not there in its place is a pair of vice grips lol so I got to get that off the z71 do this thing won't be always on high heat. Anyone got any tips on how to shove the clutch pedal up into place? Do I have to remove the gray electric box were the wire harness goes through the firewall? Or can I get it past it without removing it? I got it out of the z71 with all that in place but going into the Tahoe hasn't been successful yet. I forgot to get a pic of the master cylinder hole I will take one if I work on it tomorrow. Ignore the bite marks were some idiot tried using pliers to unscrew the 4wd shifter before realizing that they are glued on
Dneel81
OKC
I put my clutch pedal in without taking anything out. It will fit but it's painful. Getting the socket up in there and then getting the actual wrench on said socket is an exercise in patience. I did take the seat out so I could lay down looking up into what was underneath the dash.
Oh yeah, I had the brake pedal (automatic pedal) out when I put the clutch pedal in. Figured on more room. Not sure it made any difference.
87carl
87carl
I still haven't even attempted to pull brake pedal off either truck is the brake pedal hard to get out? What has to be removed to get it out? It looked like it would be a pain so I haven't bothered to try yet.
Dneel81
OKC
If I remember correctly it's just a bolt and a clip to the brake actuator. It wasn't a big deal if I could do it.
87carl
87carl
Have not had a chance to work on this truck in a couple weeks weather has been bad and have had to work on some of my other projects but I did sell the motor out of the parts truck for 400 bucks which completely covers what I paid for it also sold its gas tank for 75 bucks. Hopefully I can work on this project soon.
ANHannie
