99 tahoe clock spring
K
kene
200.00 plus dollars looking for a better priced place
SunlitComet
OBS Jedi-Do Good
unknown at this time.
very unlikely for a part like that new of good quality but if you want to chance it search " Air Bag Clockspring " at rockauto.com. not oem quality tho. and with that part i would not chance it with any other then a oem part.
SunlitComet
OBS Jedi-Do Good
verify me year, make, model, engine and tilt/no tilt column, radio/no radio controls. i am pulling up different numbers then you and they are about $160.
K
kene
99 Tahoe LT
4x4
2 door
5.7
tilt no radio
got number off old part
thanks for the help Sunlitcomet
K
kene
26087318 said it fit my Tahoe
pic showed 2 wires in 2 wires out
my has 1 wire in 1 wire out
went back with the 26072086
thanks for taking the time to try and save me $ SunlitComet
SunlitComet
OBS Jedi-Do Good
you sure you have an airbag and horn because that is not right. the airbag, in order to ensure it fires, needs an absolutely great connection for both wires to it, dark green and white. horn is likely on a slip ring connection.
OklahomaSideShow
