99 Tahoe Tune up
Hoodon
Alberta, Canada
Greetings,
I cant remember the last time I had my plugs replaced on my Tahoe. I'll probably do that this spring when it warms up, ( I don't have a heated garage to get it done)
I was wondering what other things I should do for a good tune up. I will probably throw a can of SeaFoam in my tank, I don't do a lot of highway so I'm sure there is some gunk in there.
So here are my thoughts:
Plugs - any suggestions?
SeaFoam
Check transmission fluid/ flush transmission fluid
Fuel filter - any suggestions?
Anything missing?
Thanks in advance
99Yukon_Z71
Crazy Puerto Rican
Humble, TX
Dont forget Cap and rotor assemblies, plug wires, air filter, and lube undercarriage especially if in bad terrain. As far as plugs, I am running the E3's on both my 1995 Burban and 99 Yukon with no problems and awesome performance. Check em out!
cmcarr85
I just did a tune up on my 97 Tahoe...I did...
plugs
plug wires
cap
rotor
oil
oil filter
pcv valve
fuel filter
air filter clean out
92__silverado
I have always used AC Delco plugs on my chevy's and NGK's on hondas. What are you guys seeing about these E3 plugs that you like. I have read on some forums that people didn't notice any difference.
Moue
