'99 Underhood lamp will not turn off
Gzes
the drifting 2dr
Wichita tx
ok i have the same problem but i also have movable light thing that has the switch aswell... ive checked to see if the bulbs are bad and no... ive checked too see if the wires are bad but they are good and the both lead to the firewall bolt... i was wondering if i could rewire them to a different terminal and maybe it might work???
---------- Post added at 11:48 PM ---------- Previous post was at 11:46 PM ----------
---------- Post added at 11:50 PM ---------- Previous post was at 11:48 PM ----------
or where the hell is the fuse to the under hood lights? i found a fuse running from the light but its good...
4myfreedom
Washington, DC
Hello again my horn came on yesterday and would not turn off. It just burned out I guess
Now after new relay no hoorn or under hood light. What do you think it is??
qukon 95
Could be burnt wires or terminals. Just run a wire from battery then to light ..see if it works and I think there's a relay for the horn that might be bad.
hosleyb
