ABS acting up
Puke'n Yuke'n
recently my Yuke's ABS starting going off intermittently as I come to a stop... usually riiiight before the vehicle comes to a hault. Or, if Im backing out of my driveway, and brake. Its anoyying as hell. Is this a common problem with an easy fix? I will be under the truck soon doing some suspension work so I wanna nip this problem in the bud. :shooter:
LSUz71
they could just be dirty, take them off and clean while you're down there. the light is coming on the dash?
P
Puke'n Yuke'n
Nope, surprisingly no dash light. I was planning on cleaning and inspecting. These are still the style where it's a gear type disc with a bunch of teeth and the sensor that reads it right?
That's the only one I'm familiar with.
P
Puke'n Yuke'n
BUMP!!!
anyone have any insight here? I rammed into a parked Caravan as I was pulling into a parking spot the other day!! (because of the ABS) I tracked down the owner and luckily he was cool, "ohhhh dont worry, Im giving this to my grand daughter anyways, it will be taking some abuse".
LOL
greenhornet
Ontario,Canada
GM has a bulletin about low speed ABS coming on and it involves cleaning the ABS sensors at the wheel where they mount in the bearing hub.
P
Puke'n Yuke'n
^^^^^ right on man, I should have it in the shop tomorrow to lower it... just been so buy latley. Ill clean the shit out of all of it. Thats gotta be the prollem cuz its ONLY at very low speeds.... right where I am about to stop. Never when Im going fast.
ktmhans
Connecticut
How do you know if you have the wheel and gear kind? I have an 04 w stable trac. I was under the impression it was electronic
Z-56 Hoe
What do I do????
Houston
My 2001 Tahoe had that Problem but My ABS Light came on a couple of years ago and the brakes worked fine unless that ABS light went out then I couldn't stop for Shit. Replace You wheel speed sensors in front they are $48 a piece and its should be done. if that doesn't fix it, Then it could be one of two things the ABS Pump dohicky or the ABS module. Both of those items are mounted together on the inside of the driverside frame rail. I have Replaced Both of those and my Wheel speed sensor. Mine Works great now.
I Hope that this helps.
is Yours a 2000-2002? if so there is a TSB on the Brakes for those.
daddylonglegs21
